Hi Guys,
I hope somebody can give me a tip how to remove noise from a POV-ray render of a glass object.
I made the model in LDD, exported it in LDD and converted the model with LDview to the POV format.
I used ambient lighting (3 standard light sources changed to ambient lights).
But as you can see the transparent train window shows noise.
Does anyone have a tip for me to reduce/remove the noice?
Thanx!
Does this part have a pov equivalent ? If yes, it is maiby because there are coincident surfaces which make noise in povray.
Solution would be not to use the LGEO equivalent or to create your own without the problem.
(2016-08-28, 13:33)Damien Roux Wrote: [ -> ]Does this part have a pov equivalent ? If yes, it is maiby because there are coincident surfaces which make noise in povray.
Hi Damien,
Thanks for your response. I checked the /lg/ directory and there is a equivalent: lg_4036.
How do I bypass this LGEO version?
(2016-08-28, 19:12)Bas Wrote: [ -> ]Hi Damien,
Remove this in your LGEO.xml file :
<Element>
<LDrawFilename>4036.dat</LDrawFilename>
<POVName>lg_4036</POVName>
<POVName Alternate="Clear">lg_4036_clear</POVName>
<Dependency>LGDefs</Dependency>
<POVFilename>lg_4036.inc</POVFilename>
<MatrixRef>LGEOTransform</MatrixRef>
</Element>
(2016-08-28, 21:08)Damien Roux Wrote: [ -> ] (2016-08-28, 19:12)Bas Wrote: [ -> ]Hi Damien,
<Element>
</Element>
Will do! Thanks! I will let you know if it works!
Clear plastic parts look too "milky" in LGEO/POV output IMO.
(2016-09-16, 5:59)Michael Horvath Wrote: [ -> ]Clear plastic parts look too "milky" in LGEO/POV output IMO.
Try using radiosity instead of classic lightning.
(2016-09-16, 6:47)Damien Roux Wrote: [ -> ] (2016-09-16, 5:59)Michael Horvath Wrote: [ -> ]Clear plastic parts look too "milky" in LGEO/POV output IMO.
Yes, I am using LGEO. Here's a good example:
https://www.flickr.com/photos/[email protected]/
You can hardly see through the glass.
Looks like I need to revive my lugnetcolors.inc file
Also +1 for radiosity. Transparency is rendered way better
Try to get an updated lg_colors.inc file. Try the ldraw AIOI.
(2016-09-26, 6:26)Damien Roux Wrote: [ -> ]Try to get an updated lg_colors.inc file. Try the ldraw AIOI.
I could only find "lg_color.inc" not "lg_colors.inc".
What is the modification date for your copy of this file? The changelog for the one I'm using says, "2013-05-27 Owen Burgoyne altered reflection for transparent parts" for the latest version.
Yes, it is that one lg_color.inc
Could you post it here, I will have a look and compare it to mine.
(2016-09-26, 8:51)Damien Roux Wrote: [ -> ]Yes, it is that one lg_color.inc
Here it is.
