(2016-08-23, 7:21)Jarema Wrote: [ -> ]Following this topic http://www.eurobricks.com/forum/index.ph...pic=137193. I replace my ldraw.xml file. Then after export. Too motor go in wrong direction. Any idea how fix this is welcome.
It is something to do with the angle of rotation of the motor hub within LDD. I took your model, deleted the parts which prevented me from rotating the motor hub and then rotated just the hub. I then exported it as an LDR file from within LDD and opened the resulting file in LDCAD. The following image shows the result;
attachment=2448]
I can't be more specific than this as I came across the solution by "fiddling around" but hopefully this provides you with enough of a lead to resolve your issue.
Regards,
David
