2016-08-18, 22:27
again, 5 bug fixes, PrimGen2 and new features with a not so primitive 0.8.22 release...
...well, however, in the next days I still want to write more content for the wiki/manual.
Changelog:
(9 new features and 5 bug fixes)
What will the next release 0.8.23 deliver? Bug fixes*, maybe more unit calculator features, buttons for view angles, buttons for every(!) action from the 3D context menu... usability should be more important for 0.8.23.
* oh dear..., I still need to reproduce some errors...
System Requirements:
Minimum System Requirements:
Changelog:
- ...use a "new" tool: A PrimGen2 clone is now added to the list of tools.
- ...choose whether Intersector should hide things or not (default is not to hide).
- ...benefit from "realtime" asynchronous identical line detection. LDPE detects now duplicates during input with very low latency.
- ...benefit from a better "Save As..." implementation. It shows a warning if a file is going to be overwritten.
- ...set the thickness of the lines (type 2 or 5) to zero.
- ...to see your LDraw username / real name on the header dialog ("Add a comment or header entry...").
- ...benefit from the fact that the position of the divider between the text and the 3D editor gets restored on start.
- ...use buttons to quickly "fullscreen" either the text or 3D editor and a third icon which restores the divided view.
- ...use buttons to maximise / rearrange the area on the left side of the 3D view (selection, snapping, part tree, primitive area).
- ...set the second line for an angle protractor to a defined length.
- "Toggle Comment" / "Toggle !TEXMAP" caused data corruption when it was toggled on the last line of a file.
- The "Selection:" tab was broken (it was not possible to edit lines, distance meters and subfile references)
- You were not able to open a file in the text editor sometimes (on separate window mode).
- Wrong line width was used in "Special Condline Mode" / "Random Colour Mode".
- When you opened a file in the 3D editor sometimes it was not added to the recent file list.
- Download the zip-Archive
- Java Runtime Environment (JRE) 1.8
- RAM: 4GB
- Video-Memory: 512 MB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7, Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
- RAM: >4 GB
- Video-Memory: >=1 GB
- Free Disk Space: 512 MB
java -d64 version
