2016-08-06, 15:31
Hey,
again, 10 bug fixes and new features with a fresh 0.8.21 release...
...in the next days I want to write more content for the wiki/manual.
Changelog:
(8 new features and 10 bug fixes)
What will the next release 0.8.22 deliver? Bug fixes* (regarding Flipper / selection filter) and non-standard primitives, more features for the angle protractor, real-time identical line detection...
* well..., I need to reproduce the errors first. I was not able to...
System Requirements:
Minimum System Requirements:
Changelog:
- ...set the second line in a angle protractor to a defined angle (with the selection tab).
- ...decide when "Move Adjacent Data" will be deactivated (new option).
- ...orientate the manipulator relative to the vertex location.
- ...set the vertex position to the position from a clipboard vertex.
- ...set the vertex position to the manipulator position.
- ...remove the target type from the selection (switch the object type while holding Alt).
- ...deselect an object with the selection rectangle (while holding Ctrl+Alt).
- ...benefit from more digits on some important numerical fields.
- Issues regarding "Move Adjacent Data".
- The red close cross on the tabs in the 3D editor did not close the correct tab sometimes.
- It was not possible to measure an existing edge line / triangle because LDPE prevented the creation of a distance meter / protractor on top of an edge line / triangle.
- Various usability bugs with "Open Part File" / "Save as..."
- Drag&Drop a file to the text editor opened the file in the 3D window, too (when sync. tabs was off).
- Drag&Drop a file to the text editor created new superflous tabs when a revert was cancelled.
- "New Part File" from the text editor opened the file in the 3D window, too (when sync. tabs was off).
- A change to the colour palette deleted the palette separator all editor windows.
- "Open Part File" from the text editor opened the file in the 3D window, too (when sync. tabs was off).
- "Save As..." from the text editor opened the file in the 3D window, too (when sync. tabs was off).
- Download the zip-Archive
- Java Runtime Environment (JRE) 1.8
- RAM: 4GB
- Video-Memory: 512 MB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7, Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
- RAM: >4 GB
- Video-Memory: >=1 GB
- Free Disk Space: 512 MB
java -d64 version
