2016-07-30, 22:21
Hello,
this could be version 0.9.0... but it's still 0.8.20... the best is yet to come.
Changelog:
(11 new features and 5 bug fixes)
What will the next release 0.8.21 deliver? Bug fixes, selection and manipulator features, more features for the angle protractor...
* well..., I need to reproduce the errors first. I was not able to...
System Requirements:
Minimum System Requirements:
Changelog:
- ...use the 3D editor and the text editor in one window. You can enable this under "Options...->Misc. Options->Text and 3D editor arrangement". It needs a restart of the application.
- ...use the TJunctionFinder to just "find" possible T-junctions without changing the mesh.
- ...deselect objects only with Ctrl+Click (Ctrl+Marquee is not possible anymore).
- ...add objects to the selection (Ctrl is pressed and you use the selection marquee or Ctrl+Click).
- ...benefit from the fact that the existing selection is cleared if nothing was selected and Ctrl was not pressed.
- ...find the "Last opened Files/Projects" on the "New Part - Open Part - ..." toolbar.
- ...benefit from the fact that empty text editor windows are populated with a new tab instead of creating a new text editor window.
- ...restore the complete viewport state for different files. Each file has now its own 3D viewport configuration. Open file A, activate "Random Colours" and you switch to file B to do something different without "Random Colours". If you switch back to file A, "Random Colours" are activated again. However, this automatic feature is not limited to the random colour mode. It includes every 3D viewport setting.
- ..."group" a selection. Select non-subfile content in the 3D editor. Open the context menu over the 3D view and select "Join selection (Text Editor)" to bring together what belongs together!
- ...see a warning/info, when "Move Adjacent Data" is on (for translate/rotate/scale).
- ...benefit from the fact that "Quick Fix Similar" for vertex declarations deletes other vertices (!LPE VERTEX), too.
- SyncEdit: The cursor jumped ahead after I tried to edit a vertex
- Switching the tabs in the 3D editor modified the last visited file location.
- Some issues with the hint/warning/error tree.
- Pasting something does not disable "Move Adjacent Data".
- The selection highlight feature in the text editor was sometimes not synchronised with the 3D view.
- Other minor bug fixes (regarding undo / redo with selection and/or hidden objects).
- Download the zip-Archive
- Java Runtime Environment (JRE) 1.8
- RAM: 4GB
- Video-Memory: 512 MB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7, Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
- RAM: >4 GB
- Video-Memory: >=1 GB
- Free Disk Space: 512 MB
java -d64 versionIf it's not a 64-bit version, you'll get a message that looks like:
This Java instance does not support a 64-bit JVM. Please install the desired version.In general, I recommend to install the 64-bit version of the JVM for Java 8.
![[Image: selection_ambiguity.png]](https://lh4.googleusercontent.com/-3K28mJjct_0/V57hrFoyo5I/AAAAAAAAAtg/vThd_G28zpcNmQfD32UPRJ_cxvjRd96PgCL0B/w1535-h893-no/selection_ambiguity.png)
