2016-07-22, 23:34
Hi :)
you wanted some tabs? Version 0.8.19 delivers it... ;)
Changelog:
(5 new features and 4 bug fixes)
What will the next release 0.8.20 deliver? Bug fixes and improvements for the new tab feature...
System Requirements:
Minimum System Requirements:
Changelog:
- ...use tabs in the 3D editor along with the tree on the left side.
- ...hit a button to synchronise the tab selection from tabs in the 3D editor with the text editor.
- ...see a dialog when you try to re-load an unsaved file again.
- ...smooth a set of vertices (with realtime preview)
- ...access the colour palette functions (load / save / reset) from a sub-menu.
- ...benefit from little performance improvements / refactoring.
- [Recurring] "Conditional Control Point Vertices" caused flickering on multiple views.
- Annoying mouse issues with the manipulator.
- The selection highlight feature in the text editor was sometimes not synchronised with the 3D view.
- [CSG] Rotating a part at 90 degree: It got undesired 0.0 digits.
- One manipulator icon was a duplicate.
- Download the zip-Archive
- Java Runtime Environment (JRE) 1.8
- RAM: 4GB
- Video-Memory: 512 MB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7, Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
- RAM: >4 GB
- Video-Memory: >=1 GB
- Free Disk Space: 512 MB
java -d64 version
