2016-07-12, 22:00
Hi :)
next small increase to version 0.8.18... well, this time its clear what 0.8.19 will bring ;)
Changelog:
(4 new features and 3 bug fixes)
What will the next release 0.8.19 deliver? Bug fixes (selection, icons, text editor selection highlight) , usability improvements (tabs on the 3D editor), maybe some new fancy features...
System Requirements:
Minimum System Requirements:
Changelog:
- ...trigger "Show selection in Text Editor" from a button on the GUI of the 3D editor.
- ...benefit from the fact that selecting "Show Selection In Text Editor" jumps to the next selected line.
- ...benefit from the fact that a change to the colour palette is updated instantly on all editor windows.
- ...customize the colours of the selection cross (3D editor)
- Wrong BFC rendering for primitives (in the primitve area)
- TJunctionFinder eliminates lines at random (normal mode)
- The "(!)" sign is set for (part) files which are created by the PartReview tool. This is not desired. (the "(!)" sign indicates that the file is located outside the project or the library structure of the project)
- Download the zip-Archive
- Java Runtime Environment (JRE) 1.8
- RAM: 4GB
- Video-Memory: 512 MB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7, Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
- RAM: >4 GB
- Video-Memory: >=1 GB
- Free Disk Space: 512 MB
java -d64 version
