2016-06-29, 19:23
Hey :)
this month I am a little bit late, but anyway.... I found and fixed a lot more bugs! 0.8.16 has new features, too.
Changelog:
(3 new features and 14 bug fixes)
What will the next release 0.8.17 deliver? Usability improvements, maybe some new fancy features...
System Requirements:
Minimum System Requirements:
Changelog:
- ...benefit from automatically deselection of a construction tool (create quad/line/triangle...), if you select a modification tool (select/move/rotate etc...)
- ....use a shortkey to move the manipulator to the selection center (the "A" key)
- ...use linear interpolation for a complete vertex selection with the "Move On Line" feature
- Invalid parsing of 0 BFC INVERTNEXT (the parser implementation was wrong)
- "Conditional Control Point Vertices" caused flickering on multiple views.
- The behavior of automatically selecting as well the neighboring line when clicking in the line numbers bar was incorrect.
- Flipping two triangles was only possible with a different triangle colour than colour 16.
- While are able to select a surface by clicking on it, even if only a small portion is visible, you were able to select only lines/condlines if BOTH end vertices were visible.
- Rounding issues (NullPointerException)
- Helper function issues with vertices and their relationship to LDraw data (NullPointerException)
- "Hide & Show" issues (NullPointerException)
- Clipboard issues (NullPointerException)
- Colour change issues (NullPointerException)
- Cut and delete issues (NullPointerException)
- The subfile compiler meta command (" 0 !LPE INLINE") created sometimes a new virtual part file, but it did not remove the old one!
- There was a synchronisation bug regarding the 3D manipulator.
- When you mirrored a selection, the winding of triangle/quads was correctly inverted. But primitives in selection were not BFC inverted!
- Download the zip-Archive
- Java Runtime Environment (JRE) 1.8
- RAM: 4GB
- Video-Memory: 512 MB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7, Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
- RAM: >4 GB
- Video-Memory: >=1 GB
- Free Disk Space: 512 MB
java -d64 version
