I am searching for the Parts DAT from The Porsche GT3 RS
23800 Wheel Porsche
23799 Tyre 81,6x44
26530 5X15X2 PANEL WHEEL ARCH w. Print left
26531 5X15X2 PANEL WHEEL ARCH w. Print right
24118 5X15X2 PANEL WHEEL ARCH only Printing
24119 3x7x2 Bricks, Special Circles And Angles
23801 WHEEL BEARING BACK W/ CROSS HOLE
26287 CROSS AXLE, EXTENSION, 3M
Thanks
Thorsten
I am keen of doing these parts, but unfortunately I have not them yet
PS: I deleted your wrongly placed post.
(2016-06-12, 5:22)Philippe Hurbain Wrote: [ -> ]I am keen of doing these parts, but unfortunately I have not them yet
Thanks. I will loock that i can make you a 2D Draw in the nex Days.
Thorsten
Detailed photos shot from many directions might help too...
(2016-06-12, 13:27)Philippe Hurbain Wrote: [ -> ]Detailed photos shot from many directions might help too...
Well, 24119 is pretty obvious, isn't it?
(2016-06-12, 17:42)Merlijn Wissink Wrote: [ -> ] (2016-06-12, 13:27)Philippe Hurbain Wrote: [ -> ]Detailed photos shot from many directions might help too...
Probably, but I'm not sure about the structure below the "1x5 beam".
You can view it on
this image from Jim's review on EuroBricks.
(2016-06-14, 4:38)?Thorsten Wrote: [ -> ]And this is the link to the Picures of all neu Parts and stickers
http://bricksafe.com/pages/Thorsten50/porsche
Great! Now if you can provide as many measurements as possible, especially:
- Diameter/width of the wheel rim
- height of wheels spokes at various places
- There seem to be a ridge over the wheel passage in 26530 part. Height of this ridge, if any? (Shape of this part will be tough to generate...)
- If you have access to a flat bed scanner, a scan of 26530 would be helpful.
- One or two photos of 26530 seen from top?
- Distance between middle of dark grey pins and pin holes of 23801? And I have no hint of its internal structure
Well done! Please note the correct number for the tire is 23799 not 32799 as it is in your drawing.
I did scan the sticker sheet before applying them :-)
I will do the stickers and the 1x1 Tile round with the badge
Do you need more pics of the inside of the panel 24119?
Getting 23801 out of the car might be a bit of a problem right now...
Maybe you could create a pdf or a svg instead of pixelating the drawing into png? that would improve legibility...
(2016-06-15, 13:20)Philippe Hurbain Wrote: [ -> ]Maybe you could create a pdf or a svg instead of pixelating the drawing into png? that would improve legibility...
PDF I can do. But need a little bit time to install AutoCAD to convert the dxf.
(2016-06-16, 0:32)Thorsten Wrote: [ -> ] (2016-06-15, 13:20)Philippe Hurbain Wrote: [ -> ]Maybe you could create a pdf or a svg instead of pixelating the drawing into png? that would improve legibility...
I can live with a dxf, got converters too...
Could someone confirm the overall length of wheel arch? Using Thorsten measurements (and approximations from Porsche photos) I find something around 128mm = 16L, but part is supposed to be 15x5x2 ???
(2016-06-17, 19:16)Philippe Hurbain Wrote: [ -> ]Could someone confirm the overall length of wheel arch? Using Thorsten measurements (and approximations from Porsche photos) I find something around 128mm = 16L, but part is supposed to be 15x5x2 ???
120x16x40 mm (15x2x5L) Names and dimensions from the request are Original from Lego Shop
(2016-06-18, 8:22)Thorsten Wrote: [ -> ]120x16x40 mm (15x2x5L) Names and dimensions from the request are Original from Lego Shop
Then I don't understand how it can work with an arch length of 109mm according to your image
http://bricksafe.com/files/Thorsten50/po...G_0675.JPG
109mm + 2 x beam hole lengths (2x8 mm) = 125mm min...
(2016-06-18, 9:25)Philippe Hurbain Wrote: [ -> ] (2016-06-18, 8:22)Thorsten Wrote: [ -> ]120x16x40 mm (15x2x5L) Names and dimensions from the request are Original from Lego Shop
Then I don't understand how it can work with an arch length of 109mm according to your image http://bricksafe.com/files/Thorsten50/po...G_0675.JPG
Sorry my mistake. I had picked me for the night shift in the early morning.
It should be 99mm not 109
(2016-06-15, 12:54)Philippe Hurbain Wrote: [ -> ]Hi all,
(2016-06-14, 20:11)Gerald Lasser Wrote: [ -> ]I did scan the sticker sheet before applying them :-)
Excellent!
there's a link:
http://www.brickshelf.com/gallery/lg0088...er_008.jpg
I will start work on this earliest in a week from now, need to finish some MOCs for an event :-)
Let's say it's for the community, not for you specifically
... and you helped me a lot with your measurements.
OK. For the community. :-)
how it looks with the stickers and the 1x1 Tile Printed (RS)
