When I use part 6141 (plate 1x1 round) LDCad crashes on my machine @ home (old laptop with low specs).
This is an alias ("~moved to" or "=moved to") parts. Isn't that strange too?
Using 4073.dat everything runs fine.
I know there must be more parts that cause crashes.
4073 is actually the moved to part. It's moved to 6141.
Both work fine in my LDcad (both 1.5 and 1.6) though. I've never had a certain part crash LDcad
(2016-05-31, 18:16)Jaco van der Molen Wrote: [ -> ]When I use part 6141 (plate 1x1 round) LDCad crashes on my machine @ home (old laptop with low specs).
Is this in the last 1.5 version, as it reminds me of the bug
- [PartBin] Alias parts having shadow content will no longer potentially crash the program when rendered in a bin cell.
I fixed in 1.5 beta 1a
Right. I work with the normal 1.5 version, not beta.
And, loading LDCad the round 1x1 plate is not currently visible in the partbin, only in the model.
The strange thing is that when loading a model all these blue and green + signs are visible while rendering the model.
Only where the round 1x1 plate is going to be, it looks very different. Seems no + signs but blue dots or something. I'll try to make a screenshot before the crash to illustrate this later today.
And the crash does not happen with the same model on my PC at work.
(2016-05-31, 18:22)Merlijn Wissink Wrote: [ -> ]4073 is actually the moved to part. It's moved to 6141.
Ah, right. My mistake :-)
(2016-06-01, 5:46)Jaco van der Molen Wrote: [ -> ]And, loading LDCad the round 1x1 plate is not currently visible in the partbin, only in the model.
Blue crosses are files being loaded/parsed.
Green crosses are files (waiting to) being prepped for rendering.
Yellow crosses are files of which the render prep failed, maybe the gpu is out of memory or something, The logfile might give some more insight.
Red crosses are missing files.
Here is what it looks like where the 1x1 round plates should be using 6141:
attachment=2328]
A few parts render complete then crash.
(2016-06-02, 17:53)Jaco van der Molen Wrote: [ -> ]A few parts render complete then crash.
Could you send me the logfile(s) as it should indicate which part/file it was working on during the crash.
(2016-06-02, 19:22)Roland Melkert Wrote: [ -> ]Could you send me the logfile(s) as it should indicate which part/file it was working on during the crash.
OK, I'll clear the logs and start a fresh one.
Sorry Roland, didn't have time yet to reproduce the crash and send the logs. Will do this a.s.a.p.
LDCad keeps crashing here (old laptop). Now in a model without 6141.
Though 6141 is mentioned in the log?
Here is that log, Roland. Perhaps you can take a look?
