2016-05-09, 16:12
Hey :D
showtime for LDPartEditor 0.8.13!
Changelog:
(7 new features and 2 bug fixes)
What will the next release 0.8.14 deliver? Focus on bug fixes and then usability improvements...
System Requirements:
Minimum System Requirements:
Changelog:
- ...use a new tabbed "Add Metadata" window.
- ...benefit from better "Sort" performance.
- ...configure all the settings from the "Welcome Dialog" in the "Options Dialog", too.
- ...select a line of code by clicking on the line number in the text editor (it is possible to extend the selection while pressing Ctrl.)
- ...synchronise the manipulator between multiple perspectives (right click on 3D view, "Synchronise..."->"Manipulator").
- ...synchronise the translation of the view between multiple perspectives (right click on 3D view, "Synchronise..."->"Viewport Translation").
- ...synchronise the zoom level between multiple perspectives (right click on 3D view, "Synchronise..."->"Zoom").
- "Copy" threw an exception in some rare cases
- The generated file name for downloaded files was not correct (PartReview tool)
- Download the zip-Archive
- Java Runtime Environment (JRE) 1.8
- RAM: 4GB
- Video-Memory: 512 MB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7, Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
- RAM: >4 GB
- Video-Memory: >=1 GB
- Free Disk Space: 512 MB
java -d64 version
