2016-04-30, 14:13
Hi :)
here is LDPartEditor 0.8.12 with the new PartReview tool.
Changelog:
(9 new features and 4 bug fixes)
What will the next release 0.8.13 deliver? An automated way to place rect*.dat primitives, more settings in the options dialog, a cleaner "Add Metadata" GUI layout, ...
System Requirements:
Minimum System Requirements:
Changelog:
- ...use the new "PartReview" tool. Enter a part name and start a review in no-time!
- ...use the new "Decolour" function to quickly remove all colours from a file.
- ...use the new !LPE CSG_TRANSFORM meta command to transform and clone existing CSG bodies.
- ...use the new !LPE CSG_MESH meta command to convert the following LDraw triangles and quads (type 3 and 4) to a CSG mesh.
- ...use the new !LPE CSG_EXTRUDE meta command to generate a CSG mesh from the following PathTruder input lines (type 2).
- ...adjust the rotation center of the view by double clicking on CSG surfaces.
- ...benefit from better performance of the MeshReducer tool.
- ...benefit from better performance of "Round" (Text Editor only).
- ...benefit from better (but slower) CSG triangulation.
- Mirroring now correctly preserves the surface winding.
- The protractor is now drawn without lighting.
- A selection conflict with protractors and triangles is resolved.
- Issues with "Select All", "Select Same Colour" in combination with CSG are gone.
- Download the zip-Archive
- Java Runtime Environment (JRE) 1.8
- RAM: 4GB
- Video-Memory: 512 MB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7, Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
- RAM: >4 GB
- Video-Memory: >=1 GB
- Free Disk Space: 512 MB
java -d64 version
