Full Version: [LDPartEditor] 0.8.11b Beta Released
I released 0.8.11 this week... It contained a bug and no triangle selection was possible. I had to fix it with release 0.8.11b... Sorry :|
Hey!
oh well, finally there is a 3D CSG manipulation feature release with LDPartEditor 0.8.11b...
This one was difficult, but the results are worth it :)
[Image: imgDuke2.png]
Changelog:
(6 new features and 1 bug fix)
  • ...to manipulate the CSG bodies in the same way as the sub-parts (supports also colour changes, "Select All", "Select all with Same Colours" and "Select None", global and local transformation).
  • ...to quickly convert selected triangles into quads.
  • ...to create and use angle protractors for 3 points.
  • ...to create and use distance meters between 2 points (distances depend on local or global manipulator settings).
  • ...use a little unit converter on the 3D editor window (located at the snapping area).
  • ...to benefit from better undo/redo performance.
  1. If you copied a LPE vertex and then tried to move one of them, both copies were moved ("Move Adjacent Data" is OFF).
I had to release 0.8.11b a few hours after 0.8.11 was out. Because of a triangle selection bug!!!
What will the next release 0.8.12 deliver?
A PartReview Tool, more CSG improvements, inverted surface winding when mirroring, better performance with "Round" in the text editor.
  1. Download the zip-Archive
  3. On windows, double-click "run.bat" to start LDPE.
  4. On linux/mac, you have to excecute the shell script "run.sh" to start LDPE.
Please note that this software is in the beta stage. Although, LDPE 0.8.11b was tested, there are already known issues  for this release. There is a potential risk of data loss.
  2. On linux/mac, you have to excecute the shell script "update.sh".
System Requirements:
Minimum System Requirements:
  • Java Runtime Environment (JRE) 1.8
  • Operating System (32/64bit): Windows [XP; Vista; 7 or newer], Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
  • RAM: 4GB
  • Video-Memory: 512 MB
  • Free Disk Space: 100 MB
Recommended Requirements:
  • Operating System (64bit): Windows 7, Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
  • RAM: >4 GB
  • Video-Memory: >=1 GB
  • Free Disk Space: 512 MB
java -d64 version
I fear something is very wrong in this release.
I cant select triangles or quads if there is a primitive behind it. One of the "hidden" surfaces in the primitive is choosen instead.
I can't undo a inlined subfile, only a inlined primitive.
I fixed these issues now with release 0.8.11b.
Sorry :)
You are fast!!
Thanks.
