2016-04-11, 21:42
Hey!
ten is my lucky number... and here is LDPartEditor 0.8.10b ;)
Changelog:
(8 new features and 4 bug fixes)
What will the next release 0.8.11 deliver? A feature to edit CSG shapes in the 3D view, quick triangle-to-quad conversion, measuring tools, a unit converter...
System Requirements:
Minimum System Requirements:
Changelog:
- ...customise GUI colours with the new "Options" dialog (text / 3D editor).
- ...activate/deactivate the error detection for new faces (with the new "Options" dialog)
- ...activate/deactivate no-structure-aware sorting (text editor)
- ...copy/cut/delete modifies the currently "selected" line in the text editor (without text selection, it works now on the line where the caret is placed, too)
- ...benefit from better performance / usablility for "Toggle Comment / Toggle TEXMAP" (text editor)
- ...benefit from better performance for "Synchronise Folders / Editor Content".
- ...benefit from auto-removal of CR/LF line endings at the end of the file (on save)
- ...benefit from usability improvements for Add... Line, Triangle, Quad & Condline (the selection rectangle does not create a new vertex anymore)
- Subfiles references with "s\" as prefix were not found when they were located in the same folder as the parent file
- Toggle comment/toggle !TEXMAP on multiple lines did not work as expected.
- SymSplitter: Result was shifted if there was a "0 BFC INVERTNEXT"
- Bounding-box calculation errors with empty sub-files (some sub-files were invisible).
- Download the zip-Archive
- Java Runtime Environment (JRE) 1.8
- RAM: 4GB
- Video-Memory: 512 MB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7, Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
- RAM: >4 GB
- Video-Memory: >=1 GB
- Free Disk Space: 512 MB
java -d64 versionIf it's not a 64-bit version, you'll get a message that looks like:
This Java instance does not support a 64-bit JVM. Please install the desired version.In general, I recommend to install the 64-bit version of the JVM for Java 8.
