Is there a way to delete reference lines in LD Pattern Creator - I'm using version 1.6.1
Thanks
Reuben
You just have to...
1. activate the reference line mode,
2. select the line,
3. and hit the "Delete" key (or choose "Edit->Delete" from the menu)
edit: In the future, it will be possible to move/scale/rotate reference lines.
Thanks - that's done the trick :-)
