2016-03-26, 12:16
Yay!
Another day, another release. Curtains up for 0.8.8!
Changelog:
(10 new features and 8 bug fixes)
Please note that this software is in the beta stage. Although, LDPE 0.8.8 was tested, there are already known issues for this release. There is a potential risk of data loss.
System Requirements:
Minimum System Requirements:
Recommended Requirements:
Changelog:
- ...insert a reference line (type 1) with Ctrl+R (Text Editor only)
- ...enable "Edge Adjacency" in combination with "Select Connected/Touching..." (instead of the default vertex adjacency)
- ...switch between "solid" edge lines and classic OpenGL lines
- ...get some usability improvements: When "Insert Objects Behind The Cursor Position" is active,
a carriage return / linefeed will be inserted (you don't have to hit the Enter button anymore)
- ...set the pivot point to the manipulator position.
- ...use a "close" menu item in the context menu of the 3D editor (to close open files in the 3D view).
- ...use a "close" menu item in the context menu of the file tree (to close open files in the 3D view).
- ...use the new "two thirds" perspective (similar to the setting in LDView)
- ...benefit from a better description for the Intersector tool.
- ...benefit from another line colour during edge/triangle/quad creation
- Risk of data loss: A rare deadlock is fixed. It occured during the development of 0.8.8 for the first time.
- Select Connected/Touching in combination "with Whole Subfile Selection" did not select the subfile.
- Several problems with empty sub-files (like "1-16chrd") are fixed.
- Primitve caching issues on Win XP (32 bit) are gone.
- The file search for file references/textures did not always use the base path of the current file.
- The hide/show state was too volatile.
- SymSplitter did not treat the first line of the file.
- An uncritical drag&drop type exception is fixed.
- Download the zip-Archive
- Java Runtime Environment (JRE) 1.8
- RAM: 4GB
- Video-Memory: 512 MB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7, Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
- RAM: >4 GB
- Video-Memory: >=1 GB
- Free Disk Space: 512 MB
java -d64 version
