Full Version: [LDPartEditor] 0.8.7 Beta Released
Yeah Smile showtime for version 0.8.7!
currently, I am on easter holidays. I have some spare time... and here is the next release! Wink
[Image: imgDuke2.png]
Changelog:
(6 new features and 8 bug fixes)
  • ...benefit from a faster program start.
  • ...toggle the visibility of conditional line control points.
  • ...drag&drop files on the 3D editor view.
  • ...drag&drop files on the text editor view.
  • ...use the new "modern" GUI layout on a fresh installation.
  • ...activate anti-aliasing on some linux systems with MESA/Gallium*
  1. Risk of data loss: When you open a file again (which was unsaved in LDPE) the file in the 3D view gets cleared.
  2. "Show selection in text editor" did not work correctly for subfiles, if the text editor was closed before.
  3. "Open Part File" from the 3D editor opens a text editor window, too.
  4. Identical lines are not detected if they have different colours.
  5. CSG does not work with invalid colour numbers.
  6. "Unselect" (Ctrl+Click) does not work for subfiles.
  7. Subfile selection issues with adjacent subfiles.
  8. The coarse/medium/fine grid buttons don't stay pushed.
  1. Download the zip-Archive
  3. On windows, double-click "run.bat" to start LDPE.
  4. On linux/mac, you have to excecute the shell script "run.sh" to start LDPE.
Please note that this software is in the beta stage. Although, LDPE 0.8.7 was carefully tested and developed, there are already known issues for this release. There is a potential risk of data loss.
  2. On linux/mac, you have to excecute the shell script "update.sh".
System Requirements:
Minimum System Requirements:
  • Java Runtime Environment (JRE) 1.8
  • Operating System (32/64bit): Windows [XP; Vista; 7 or newer], Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
  • RAM: 4GB
  • Video-Memory: 512 MB
  • Free Disk Space: 100 MB
Recommended Requirements:
  • Operating System (64bit): Windows 7, Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
  • RAM: >4 GB
  • Video-Memory: >=1 GB
  • Free Disk Space: 512 MB
java -d64 version
_______
* (on Windows, for AMD/NVIDIA cards, you have to enable anti-aliasing manually for the javaw.exe process, with AMD Catalyst or the NVIDIA Control Panel)
How do I correctly close a file from the 3D-editor?
In previous versions I could close a file by right-clicking on it, in the filemanager area, and choosing Delete.
(Delete is a very strong word. I don't like it).
If I do that in this version, a suffix is added to my file "12345.dat.bak" and I can't open it again untill I rename it in windows explorer.
I can close a file in the text editor correctly by clicking on the red cross on the file tab, but not in the 3D editor.
Magnus Forsberg Wrote:In previous versions I could close a file by right-clicking on it, in the filemanager area, and choosing Delete.
As I understand, it will be better to rename "Delete" to "Close" and avoid the superflous ".bak" suffix?
That is a very good suggestion.
At the moment, you can only open another file to overwrite the contents of the 3D view.
However, the program does not lock the files on your harddrive.
When you open a file it will be parsed and when you save it, it will be written to your harddrive.
Great! faster startup and antialiasing tip for Windows are appreciated (not yet tried the remaining improvements).
I seem to have one major issue with this release on my XP 32bit: I can't close the program. When I try to do so, the program asks to if I want to save projects, etc..., then closes the text windows but the 3D window stays open and still works normally. If I kill the program using task manager, it does shutdown, but then I can't restart it without deleting the config.gz. Maybe it's related to primitives caching? At startup, after answering library location /authorship questions config.gz is about 3k. After trying (unsuccessfully) to close the program, size of config.gz jumps to 750k or so. My config.gz is attached here if it can help to understand the problem.
Otherwise I don't think it's a good idea to save cache in the same file as general configuration. If something goes wrong with caching you loose the whole config, shortkeys, etc...
Edit:
Quote:the 3D window stays open and still works normally.
Not quite: when trying to Undo something LDPE froze on "loading data..."
Nils Schmidt Wrote:currently, I am on easter holidays. I have some spare time... and here is the next release! Wink
Be assured I'll do my best to fill it for my personal benefit :-) Here we go:
* I'm very happy with the copy/paste/... on a right click. You could spoil the whole thing by adding the copy/paste/... icons from the toolbar to the contextual menu
* I'd like to have a some sort of LDCalc in the 3D and Text Editor toolbar. To be clear, not the whole thing. A toolbar with LDU/mm/inch where I hammer in my digits and get the converted result in the other boxes would be enough
* I find it tiresome that I have to select something and then hit the arrow (Next item) button in the Selection tab in order to get it loaded. I would prefer that the values get automatically loaded as soon as I make a selection.
Anybody successfully running Intersector in LDPE?
I tried to cut out some sections of the two red cylinders and get fine looking vertices but no surfaces. Here is the code:
1 4 0 42.75 0 18.5 0 0 0 5.25 0 0 0 18.5 4-4cyli.dat
1 4 0 42.75 0 16 0 0 0 5.25 0 0 0 16 4-4cyli.dat
1 14 10 48 10 1 0 0 0 2 0 0 0 1 stud.dat
1 14 -10 48 10 1 0 0 0 2 0 0 0 1 stud.dat
1 14 10 48 -10 1 0 0 0 2 0 0 0 1 stud.dat
1 14 -10 48 -10 1 0 0 0 2 0 0 0 1 stud.dat
What I'm doing wrong?
In the code below, if I select the quad then select -> select connected, the elements of the cylo (not the cylo itself) gets selected. If I then try to move the selection, only the quad moves.
1 16 -10 1 28 -2 0 0 0 2 0 0 0 -2 1-4cylo.dat 4 16 -12 1 60 -12 1 28 -12 3 28 -12 3 60
Worse, if I cut the selection then copy, I get the following result:
1 16 -10 1 28 -2 0 0 0 2 0 0 0 -2 1-4cylo.dat 2 24 -11.8478 1 27.2346 -11.4142 1 26.5858 2 24 -11.8478 3 27.2346 -11.4142 3 26.5858 2 24 -12 1 28 -11.8478 1 27.2346 2 24 -12 3 28 -11.8478 3 27.2346 2 24 -10.7654 1 26.1522 -10 1 26 2 24 -10.7654 3 26.1522 -10 3 26 2 24 -11.4142 1 26.5858 -10.7654 1 26.1522 2 24 -11.4142 3 26.5858 -10.7654 3 26.1522 4 16 -12 3 28 -11.8478 3 27.2346 -11.8478 1 27.2346 -12 1 28 4 16 -11.8478 3 27.2346 -11.4142 3 26.5858 -11.4142 1 26.5858 -11.8478 1 27.2346 4 16 -11.4142 3 26.5858 -10.7654 3 26.1522 -10.7654 1 26.1522 -11.4142 1 26.5858 4 16 -10.7654 3 26.1522 -10 3 26 -10 1 26 -10.7654 1 26.1522 5 24 -12 1 28 -12 3 28 -11.8478 1 27.2346 -12 1 30 5 24 -11.8478 1 27.2346 -11.8478 3 27.2346 -11.4142 1 26.5858 -12 1 28 5 24 -11.4142 1 26.5858 -11.4142 3 26.5858 -10.7654 1 26.1522 -11.8478 1 27.2346 5 24 -10.7654 1 26.1522 -10.7654 3 26.1522 -10 1 26 -11.4142 1 26.5858 5 24 -10 1 26 -10 3 26 -10.7654 1 26.1522 -8 1 26 4 16 -12 1 60 -12 1 28 -12 3 28 -12 3 60
Looks like LDPE has issues with 1-16chrd (which boils down to invisible "empty.dat"). If I select several lines in text editor then hit "show selection in 3D View", all elements below line with 1-16chrd are not selected/highlighted.
You have to inline these two lines recursively:
1 4 0 42.75 0 18.5 0 0 0 5.25 0 0 0 18.5 4-4cyli.dat 1 4 0 42.75 0 16 0 0 0 5.25 0 0 0 16 4-4cyli.dat
Intersector can not do this for you.
I created a ticket for this issue 10 days ago. I will fix this with the next release.
Willy Tschager Wrote:* I'm very happy with the copy/paste/... on a right click. You could spoil the whole thing by adding the copy/paste/... icons from the toolbar to the contextual menu
Done! It will be included in the next 0.8.8 release.
Willy Tschager Wrote:* I'd like to have a some sort of LDCalc in the 3D and Text Editor toolbar. To be clear, not the whole thing. A toolbar with LDU/mm/inch where I hammer in my digits and get the converted result in the other boxes would be enough
I created some issues/tickets for this feature request.
But before I start the implementation I have to fix a few more bugs Wink
Thank you Philo for this bug report!
That's a tricky one. On my XP 32 bit system, the error did not occur.
I am sure that it is related to the new primitve caching.
Fortunately, I was able to improve the implementation for the open/save-config mechanics.
With the next 0.8.8 release, your configuaration will be independend from the data consistency of the primitive cache.
Philippe Hurbain Wrote:Otherwise I don't think it's a good idea to save cache in the same file as general configuration. If something goes wrong with caching you loose the whole config, shortkeys, etc...
It was even worse Wink I put the cache in the same object. This object stored the general configuration and the cache. This was a major design flaw and is fixed now.
Philippe Hurbain Wrote:Edit:
D'oh... you have reached an unstable state, since most of the underlying data structure is already disposed because of the event which was triggered on close.
Philippe Hurbain Wrote:In the code below, if I select the quad then select -> select connected, the elements of the cylo (not the cylo itself) gets selected.
Well, there is a solution.. did you try the "...with Whole Subfile Selection" option from the "Select..." menu?
It was implemented in March 2015 Wink
It gets even worse. At the moment, any empty subfile (like "empty.dat") can be a troublemaker.
I was able to fix this. It will be corrected with release 0.8.8.
Quote:Well, there is a solution.. did you try the "...with Whole Subfile Selection" option from the "Select..." menu?
Well, actually the problem is not that subfile is not selected, but when I copy/paste I actually inline primitive (whether or not "...with Whole Subfile Selection" is checked)
Okay. Now I understand where the problem is Smile
I created an issue.
Quote:* I'd like to have a some sort of LDCalc in the 3D and Text Editor toolbar.
More than a calculator I'd like to see a measuring tool, showing the distance between 2 vertices and the deltaX, deltaY, deltaZ distances (either in world directions or in manipulator directions). An angle protractor for 3 points would be great too!
Bug:
To get Intersector generating surfaces you have to do the selection in the 3D editor. Selecting in the Text Editor will produce all vertices needed but no surfaces.
Feature request:
The "Open in 3D Editor" button in the text editor should be automatized. When I click on a tab in the Text Editor the part should automatically be loaded in the 3D Editor. This would make the button superfluous.
Nils Wrote:the program does not lock the files on your harddrive.
No, I would say that the file is locked.
If I edit and save my file in the text editor, I close it with the red cross. I then empty the 3D editor by choosing to wiew another file in the 3D editor. I then open my file in LDDP, edit it and want to save it, I get a error message telling me the file is in use.
Or do I have to also save my project too?
Why is there two save buttons in the 3D editor? One for parts and one for projects?
I am not so keen of current implementation of random color render, I would have expected to have a uniform color in each primitive/subfile, instead of a color per facet. Now current style may be useful too...
Speaking of colors (this will be solved when we get customizable colors), the red for lines during edge/triangle/quad creation is the same as the red of BFC backwards surface. So often we have to work without visual feedback...
I've never dared to continue after trying to use Intersector. All I see is new vertices and the rest of my part strangely disappear...
All is reverted after I use Undo.
Quote:No, I would say that the file is locked.
This remains a mystery for me. Sometimes file is locked, sometimes no. Recently it seems I have been lucky with files generally not locked. Perhaps an improvement in 0.8.7?
+1
I dislike that the edge lines are randomized too...
Mostly agree (for edge lines colors), but... current implementation can be usful too Wink
Maybe it is just me, but why are the X and Z axis rotated around Y-axis in default two-third view?
[attachment=2203]
(2016-03-25, 8:09)Philippe Hurbain Wrote: [ -> ]More than a calculator I'd like to see a measuring tool, showing the distance between 2 vertices and the deltaX, deltaY, deltaZ distances (either in world directions or in manipulator directions).
Yesterday, I finished the implementation of the distance measuring tool.
Today, I will start the angle protractor implementation! :)
