2016-03-16, 11:02
I am working on duplicating lego set #75038 Anakin's Jedi Interceptor in LDraw. I have completed most of the main fuselage, but I am missing two critical pieces that don't seem to be available in MLCAD. They are the following two pieces...
Lego Part #6063484, BL part #10312pb01
Windscreen 10 x 6 x 3 Bubble Canopy Double Tapered with Square Front Cutout and Light Bluish Gray Jedi Starfighter, Two Red Triangles on Top Pattern
Lego Part #4252631, BL part #3960pb013
Dish 4 x 4 Inverted (Radar) with Radial Jedi Starfighter Cockpit Pattern
For now I have substituted the dish with a plane undecorated 4 x 4 dish that I have colored trans-clear. However, there is no suitable equivalent for the Windscreen. The closest that I could find is LDRaw part #50986 Windscreen 6 x 10 x 3 Ovoid, but that one is not suitable as a substitute. The set's windscreen has notches at the ends that can fit a 1 x 2 brick, LDRaw part #50986 doesn't have those notches.
