2011-12-07, 18:09
Aloha,
I have added to Jim DeVona's ldraw.plist, found in TextWrangler LDraw Kit (see below). So that it would do syntax highlighting in BBEdit.
Save it in text file, named ldraw.plist in
~/Library/Application Support/BBEdit/Language Modules/ldraw.plist
I would like to know how to get it to do code folding on the steps of an LDraw file.
Mahalo,
Ramón
Mahalo,
Ramón
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>BBEditDocumentType</key>
<string>CodelessLanguageModule</string>
<key>BBLMLanguageDisplayName</key>
<string>LDraw</string>
<key>BBLMLanguageCode</key>
<string>LDrw</string>
<key>BBLMColorsSyntax</key>
<true/>
<key>BBLMScansFunctions</key>
<true/>
<key>BBLMIsCaseSensitive</key>
<false/>
<key>BBLMCanSpellCheckCodeRuns</key>
<true/>
<key>BBLMKeywordList</key>
<array>
<string>!CATEGORY</string>
<string>!CMDLINE</string>
<string>!COLOUR</string>
<string>!HELP</string>
<string>!HISTORY</string>
<string>!KEYWORDS</string>
<string>!LDRAW_ORG</string>
<string>!LICENSE</string>
<string>!LPUB</string>
<string>BFC</string>
<string>CLEAR</string>
<string>LDRAW_ORG</string>
<string>PAUSE</string>
<string>PRINT</string>
<string>SAVE</string>
<string>STEP</string>
<string>WRITE</string>
<string>Official</string>
<string>Unofficial</string>
<string>Un-official</string>
<string>Part</string>
<string>Subpart</string>
<string>Primitive</string>
<string>48_Primitive</string>
<string>Shortcut</string>
<string>File</string>
<string>Model</string>
<string>Submodel</string>
<string>Element</string>
<string>Sub-part</string>
<string>Hi-Res Primitive</string>
<string>Alias</string>
<string>Cross-reference</string>
<string>ABS</string>
<string>ADD</string>
<string>AREA</string>
<string>ASSEM</string>
<string>Author</string>
<string>AXLE</string>
<string>BACKGROUND</string>
<string>BASE</string>
<string>BEGIN</string>
<string>BGT</string>
<string>BI</string>
<string>BOM</string>
<string>BORDER</string>
<string>BORDERLESS</string>
<string>BUFEXCHG</string>
<string>CALLOUT</string>
<string>CENTER</string>
<string>CHAIN</string>
<string>CMDLINE</string>
<string>COLOR</string>
<string>COLORNAME</string>
<string>COLOUR</string>
<string>COLOURNAME</string>
<string>COLS</string>
<string>CONFIG</string>
<string>CONSTRAIN</string>
<string>CROSS</string>
<string>DIVIDER</string>
<string>ELECTRIC_CABLE</string>
<string>ELSEPOV</string>
<string>END</string>
<string>ENDPOV</string>
<string>FIBER_OPTIC_CABLE</string>
<string>FLEX_CABLE</string>
<string>FLEXHOSE</string>
<string>FLEXIBLE_AXLE</string>
<string>FLEXIBLE_TUBE</string>
<string>GHOST</string>
<string>GRAYED</string>
<string>GROUP</string>
<string>HEIGHT</string>
<string>HIDE</string>
<string>HORIZONTAL</string>
<string>ID</string>
<string>IFNOTPOV</string>
<string>IFPOV</string>
<string>IGN</string>
<string>INSIDE</string>
<string>INSTANCE_COUNT</string>
<string>LDRAW</string>
<string>LPUB</string>
<string>MARGINS</string>
<string>MATRIX</string>
<string>MLCAD</string>
<string>MULTI_STEP</string>
<string>Name</string>
<string>NUMBER</string>
<string>OFFSET</string>
<string>OUTSIDE</string>
<string>PACK</string>
<string>PAGE</string>
<string>PART</string>
<string>PLACEMENT</string>
<string>PLASTIC_TREAD</string>
<string>PLI</string>
<string>PLIST</string>
<string>PNEUMATIC_TUBE</string>
<string>POINT</string>
<string>POINTER</string>
<string>REL</string>
<string>REMOVE</string>
<string>RETRIEVE</string>
<string>RIBBED_TUBE</string>
<string>RIGID_TUBE</string>
<string>ROTATE</string>
<string>ROTATION</string>
<string>ROTSTEP</string>
<string>ROUND</string>
<string>RUBBER_BAND</string>
<string>RUBBER_BELT</string>
<string>RUBBER_TREAD</string>
<string>SCALE</string>
<string>SEPARATOR</string>
<string>SHOW</string>
<string>SIZE</string>
<string>SKIP_BEGIN</string>
<string>SKIP_END</string>
<string>SORT</string>
<string>SPRING</string>
<string>SQUARE</string>
<string>STEP_NUMBER</string>
<string>STORE</string>
<string>STRETCH</string>
<string>SUB</string>
<string>SUBS</string>
<string>SYNTH</string>
<string>SYNTHESIZED</string>
<string>TRANS</string>
<string>TRANSFORM</string>
<string>TRANSLATE</string>
<string>VERTICAL</string>
<string>WIDTH</string>
<string>YESNO</string>
</array>
<key>BBLMSuffixMap</key>
<array>
<dict>
<key>BBLMLanguageSuffix</key>
<string>.mpd</string>
</dict>
<dict>
<string>.ldr</string>
</dict>
<dict>
<string>.dat</string>
</dict>
</array>
<key>Language Features</key>
<dict>
<key>Function Pattern</key>
<string>^\s*0\s+FILE\s+(?P<function_name>\S+)\s*$</string>
<key>Identifier and Keyword Character Class</key>
<string>0-9A-Z_a-z!</string>
<key>Comment Pattern</key>
<string>^\s*0\s+(?!!|STEP|ROTSTEP|Name|Author|FILE|Official|Unofficial|Un-official).*</string>
<key>Skip Pattern</key>
<string></string>
<key>String Pattern</key>
<string></string>
</dict>
</dict>
</plist>
