2016-03-07, 22:12
with a little overdue of one month*... here is the LDPartEditor 0.8.5 Beta release!
I will now focus on tutorial videos since this version should be stable enough to work with (though its still a beta).
You can download LDPE from this page:
Changelog:
Please note that this software is in the beta stage. Although, LPE 0.8.5 was carefully tested and developed, there are already known issues for this release. There is a potential risk of data loss.
LPE is a 3D CAD application: The overall system requirements are higher. While I recommend to use a powerful 64-bit multicore system, it could be possible, to run LPE on older machines as well.
System Requirements:
Minimum System Requirements:
Recommended Requirements:
___
* normally, I want to do at least one release per month.
Changelog:
- ...use up to 9 decimal places for rounding (coordinates + matrix). [requested by Gerald]
- ...open the part in the 3D editor from the text editor window (orange "3D" button) [requested by at least two users]
- ...use "save as..." to store files under a new filename (text editor only) [requested by Magnus]
- ...use a button for single vertex manipulation ("SyncEdit") in the text editor [requested by Willy]
- ...benefit from a new "how-to-use" description for the SlicerPro2 tool.
- Rectifier created rect#.dat primitives when "Split" and "SlicerPro2" were used.
- Rectifier created rect-prims that were scaled in three dimensions.
- Fixed an issue which was related to the parsing of the !HISTORY meta command
- Fixed a null pointer issue with "Add Quad" and other "Add..." functions.
- Fixed incorrect cursor movement when single vertex manipulation was active.
- Fixed a GUI access issue, which occured on drag&drop with text editor tabs.
- Fixed a random null pointer issue, which could disable the tab from the text editor window when more than one tab was opened.
- In some rare cases when a flat subfile was scaled in X/Y or Z and the transformation matrix contained more than one space as seperator between the values, the corresponding "Quick Fix" was not able fix the scaling.
- Download the zip-Archive
- On windows, double-click "run.bat" to start LPE.
- On linux/mac, you have to excecute the shell script "run.sh" to start LPE.
- Java Runtime Environment (JRE) 1.8
- RAM: 2.5GB
- Video-Memory: 512 MB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7, Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
- RAM: >4 GB
- Video-Memory: >512 MB
- Free Disk Space: 512 MB
java -d64 version
___
