Full Version: LDraw All-In-One-Installer 2011-01 Now Available
The LDraw All-In-One-Installer 2011-01, in short AIOI, has now been released:
* It comes with the latest LDraw Parts Library update 2011-01 as well as MLCad.ini file.
* Thanks to J.C. Tchang the installer from now on also "speaks" French.
* Furthermore it detects an old version of the All-In-One-Installer and on request uninstalles it prior copying new files.
* It lets you also decide if you wanna register LDView to generate thumbnails of LDraw files in the Windows Explorer.
* The search for an installation done manually or by third party software is no longer performed. The quick search did not perform as expected and a deep scan would require too much time.
The AIOI supports Windows XP (Home and Pro), Windows Vista (all versions) and Windows 7 (all versions). On 64-Bit Operating Systems it will install in the "Program files (x86)" folder. The Installer will NOT run on Windows 95, 98, ME, NT Ver 4, 2000, or XP below SP2.
You can download the AIOI by going to the download database under the heading Critical Files and Libraries.
