2016-02-03, 8:19
2016-02-03, 8:34
2016-02-03, 8:54
I've missed it indeed. Oops.
Thanks!
Thanks!
2016-02-03, 8:55
No problem! I'm not in a hurry or anything
2016-02-10, 21:39
Orion got the (newest version of) the site working. Super!
See set 1713 as an example.
I'll probably start adding the current OMR files tomorrow. Finally some content
2016-02-11, 16:59
Would it be possible to have a small picture of the set, first in every row, on the page All files?
2016-02-11, 18:16
LOVE IT!
However some remarks:
* The title of the single pages should be LDraw OMR - <set number> not viceversa
* The title of the all files page should be LDraw OMR - All available files, same goes for Statistics and About
* Latest files should also carry a rendering rather than a pic of the box.
* On the single page the "4349 Ken Drew [Ken]" should also carry the set name "4349-1 - Wild Pod - Ken Drew [Ken]"
* On the single page there should also be the theme
* Being known as extrem nitpicker I'd like to see a bit more room between the LDraw logo (which could be a tiny bit bigger) and OMR Home
* Finally the date of submission would be useful
2016-02-11, 19:45
Willy Tschager Wrote:* The title of the single pages should be LDraw OMR - <set number> not viceversaI indeed noticed that it was the other way around on the main LDraw site. I don't really mind if it's one way or the other. I'll change it in the next version.
Willy Tschager Wrote:* Latest files should also carry a rendering rather than a pic of the box.Yup. I was using set-pictures because I wanted (and actually still want) to skip the file-images and use a browser based viewer. That didn't work, but I never changed the latest-files images. It's already on the list of things to do in the next revision.
Willy Tschager Wrote:* On the single page the "4349 Ken Drew [Ken]" should also carry the set name "4349-1 - Wild Pod - Ken Drew [Ken]"Interesting one. Never noticed that. Indeed no reason to only show the set number.
Willy Tschager Wrote:* On the single page there should also be the themeYou mean on a file-page, where you can see the file-header? I skipped the theme (and all other set info), because it's a file-page. There's a difference between the two, a set page is focussed on a single set and shows all set data including all the related files. A file-page shows information about the file with a link to the set (which has the set information).
Willy Tschager Wrote:* Being known as extrem nitpicker I'd like to see a bit more room between the LDraw logo (which could be a tiny bit bigger) and OMR HomeI wanted the logo a little bigger too, but if it would be bigger, I would have to create a second header with the logo only (like on the main LDraw site). I didn't wanted to that, seemed like a waste of space. I tried to make the space between the logo and the OMR Home link bigger, but I couldn't get it done quickly, so I pushed it into the to-do list. It's not a major problem
Willy Tschager Wrote:* Finally the date of submission would be useful
I realised this too. The date of submission is already being recorded anyway, so it's just a matter of showing the data. I was also considering to add a date of the latest edit (so a creation date and a edit date).
2016-02-11, 19:47
I guess that's not that difficult. I'll see what I can do in the next version.
The all-files table is a little messed up anyway. It used to look like the table on a set-page, but for some reason it has these super high columns now, which it didn't had when there were less files.
2016-02-15, 14:43
I've made a small update to the website with some tweaks here and there. Changelog is here.
I just noticed however that there is a 'major' error when looking at certain files (for example 3798 or 3796). It seems to be a problem with encoding. I'll take a look into this. Almost all files are working fine though
