2015-12-21, 8:28
There are some new features build in now and also (as always) bugfixes and changes.
New
1) Command line option /r changed to ui less version for scanning of files only and write the report to a file in "<userdocuments>\MPDCenter""
2) Command line option /c (correct) in conjunction with /r will correct the file and write it to "<userdocuments>\MPDCenter\corrected".
3) Command line option /l (library) works with both options on the library with report and correction (library will not be touched). (auf Recifier postprocessor achten-erl.)
3) If a conditional line and a line have the same values, the conditional line will be deleted.
Changes
1) Message for wrong comment lines changed.
2) Message for not corrected triangle because of colinear vertices changed.
3) If you "Save as" then the new name is written to the "Name:"-tag of the new file.
4) the application has now a new icon
5) There is no test for flat files scaled in the flat direction.
Bugfix
1) Correct colinear quad sometimes bring wrong lines.
2) Check on file name ending ...s01 or ..p01 could generate an error.
3) using of rectifier postprocessing gave wrong messages.
4) parsing of the author line improved.
5) If a subfile could not be found the boundingbox is set to all zero.
6) If the entire file will be flushed, also the picture will be flushed and the new header
You can download the tool as always from http://ldraw.heidemann.org/index.php?page=datheader
New
Changes
Bugfix
