You can find in attached the official model 10018 Darth Maul.
Regards
Nice job! Maybe you should consider making it
OMR compliant? It's very easy for this model (see
tutorial, only the first 5 steps are needed here)
I didn't know OMR. I'll take a look at the tutorial.
Thank you !
Here you are the version OMR compliant.
Can you tell me if it is correct ?
Regards.
Yes it is! Not mandatory, but you could also add a theme entry:
0 !THEME Star Wars / Ultimate Collector Series / Sculptures
Philippe Hurbain Wrote:Not mandatory, but you could also add a theme entry:
This information is present in the file, I also added some keywords.
Sorry, I must have missed it!
You have multiple brick clashes, at both sides near the jaw line, and at the front under the chin.
You should consider using LDView's "Random Colors" feature to check for these types of common fault. It really is rather good at showing most of these up easily.
Thank you for your help !
I didn't know this feature in LDView ! I will corrected that.
Regards
