Full Version: [LDPartEditor] 0.8.4 Beta Released
Pages: 1 2 3 4 5
Hello,
as promised, here is the new feature release 0.8.4 Wink
In the meantime, I prepare the migration to Java 8. Later releases will require Java 8.
[Image: imgDuke2.png]
You can download LPE from this page:
Changelog:
  • ...use the new "MeshReducer" tool, to simplify generated CSG meshes.
  • ...use a more "aggressive" T-junction-finder (can destroy the mesh geometry under some circumstances!)
  • ...use the "Move on Line" function, to move a vertex on a line between two vertices (its a beta tool! Soon I will explain how to use this.)
The program was tested intensively with "real world" files. Especially, "Undo" and "Redo" should work now fine.
  1. Download the zip-Archive
  3. On windows, double-click "run.bat" to start LPE.
  4. On linux/mac, you have to excecute the shell script "run.sh" to start LPE.
Please note that this software is in the beta stage. Although, LPE 0.8.4 was carefully tested and developed, there are already known issues for this release. There is a potential risk of data loss.
Something can go wrong in about 100.000 lines of code.
  2. On linux/mac, you have to excecute the shell script "update.sh".
LPE is a 3D CAD application: The overall system requirements are higher. While I recommend to use a powerful 64-bit multicore system, it could be possible, to run LPE on older machines as well.
System Requirements:
Minimum System Requirements:
  • Java Runtime Environment (JRE) 1.7
  • Operating System (32/64bit): Windows [XP; Vista; 7 or newer], Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
  • RAM: 2.5GB
  • Video-Memory: 512 MB
  • Free Disk Space: 100 MB
Recommended Requirements:
  • Java Runtime Environment (JRE) 1.8
  • Operating System (64bit): Windows 7, Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
  • RAM: >4 GB
  • Video-Memory: >512 MB
  • Free Disk Space: 512 MB
java -d64 version
Some issues:
* If there isn't anything selected the shortcuts 1, 2, 3, ... for Select, Move, ... as well F2, F3, F4 ain't working
* Is there a way to move the Manipolator icons to a toolbar?
* How to show condlines properly
Hi Willy,
thanks for your feedback!
I created issues for the bugs and feature requests which were mentioned by you.
Unfortunately, I don't understand the question "How to show condlines properly?"...
Today I released version 0.8.4b.
This version includes two bug fixes regarding "Merge to Nearest..." and "Move Subfile To Manipulator".
It is also the first release which requires Java 8.
Cheers,
Nils
Hello Nils,
Today I can't start 0.8.4b. It has been running (I think) before.
I see this in the error log:
Exception in thread "main" java.lang.IllegalArgumentException: Comparison method violates its general contract!
Win7 64, Java 8 Update 66 (64-bit)
as a response to Magnus Forsbergs post, I did release a bugfix version.
Changelog:
With the release of 0.8.4c the following issues are fixed:
  • Fixed a critical bug within the primitive sorting algorithm (crash on start!)
  • Fixed a bug which disabled the possibility to split a condline.
  • Fixed a bug which could trigger an exception when the "Single Vertex Manipulation" (aka 'SyncEdit') was active
  • Fixed a bug for "Merge to nearest line" / "TJunctionFinder". They did not ignore control point lines from condlines.
  • Leading spaces from the file header stopped the header validation.
  • It was possible to modify read-only files with the functions from the "Selection:" tab.
  • RAM: 2.5GB
  • RAM: >4 GB
java -d64 version
Hi Nils,
I had great fun preparing these.
1.)
Is it posible to turn of the internal Rectifier?
Everytime I hit Save, in the text editor, it creates rect-prims I don't want.
2.)
The internal Rectifier creates rect-prims that are scaled in three dimensions.
3.)
How do I create a subfile?
I want to select all in same colour, then move them to a subfile.
The Selector from Philo does a neat trick: Select all in the same colour, and move selection to the end of the file.
4.)
Why doesn't the Save button in the viewer do the same thing as the Save button in the text editor?
Save button in the viewer wants to create/save a project and starts to create a number of folders when I use it.
Save button in the editor simply saves my file.
5.)
Where and when can I read a manual on how to use LPE?
6.)
Is it possible to change the position of the light source?
When I zoom in close, the interesting area sometimes end up being shaded, or to dark to work with.
Magnus Forsberg Wrote:4.)
And is there a trick to "Save as..."?
Magnus Forsberg Wrote:6.)
The light source is reset if you double click the left mouse button.
Found it out with when Nils advised the double click to center the manipulator to a primitive.
Hello Magnus,
I will try to answer your questions:
Is it possible to turn of the internal Rectifier?
This is a bug! LPE 0.8.4c does not rectify on save. Rectifier creates accidentally rect#.dat primitives on the whole file when "Split" and "Slicerpro" were used. It will be fixed with the release of 0.8.4d. I fixed and tested it already in my developer version.
This is a bug, too... I will try to fix it with the next release.
This is a new feature, which is easy to implement. You can already sort by colour with the text editor window as a temporary workaround. Regarding the subfile creation, you can create a subpart by clicking on "New Part File" (text- or 3D-editor) and choose the "S" folder as a target location. The philosophy of LDPE is to represent each project as a fraction of the real LDraw library structure. A project has its own "P","8","48", "PARTS" and "S" folders to be compliant with the library structure.
This is a GUI issue. The program needs a better GUI design to distinguish between "Projects" and "Part Files"... and it needs also a "Save As..." feature.
You can read a manual on JC's page and here is my official wiki. Both are WIP.
6.)
When I zoom in close, the interesting area sometimes end up being shaded, or to dark to work with.[/quote]
You can either turn off the lights (View Actions -> Lights) or reset the light source with a double click (LMB) on a location in the 3D space. The double click sets also the center of rotation and the manipulator to this location.
Leg godt
Nils
Nils Schmidt Wrote:You can read a manual on JC's page
It would be awesome if one of our French friends could translate this thing - or at least revise Mr. Google's work:
https://translate.google.com/translate?s...&edit-text=
Pages: 1 2 3 4 5
