attachment=1890]
Download MPD (OMR compliant)
Known problems: Both 8L Axles of the roll cage are a bit too long (it's slightly stressed in the real model)
Done with LDCad 1.5b1.
As you can see the helmet looks rather good
Looks good at first sight, but it seems that the figure is sitting too straight, bottom back collides with the seat and even bleeds through the back. Now that doesn't bother me a lot
You are right, this problem must occur at the main model as well, cause I copied the figure from there.
I'll correct this ASAP.
Also, the half-bushes on the right-side axle-8 are 1 ldu out of alignment with the connectors, and in comparison to those on the other side.
The figure position and the bushes are fixed.
One of the steering-arm pins is higher than the other. Although unlike the other issues it doesn't in any way invalidate the model though - just pointing it out in case the purist in you has the desire to adjust this before it hits the OMR ;-)
Thanks for spotting, if you don't mind, I would like to delete the comments to reduce this thread to it's main subject.
