2015-12-11, 9:20
I suggest to update text from primitive reference from
This change should avoid sterile discussions such as this one: http://www.ldraw.org/cgi-bin/ptdetail.cg.../u9228.dat
Quote:To avoid matrix arithmetic problems in some renderers, the third dimension ({y} in the default orientation) of two-dimensional primitives must be given a scaling factor of 1.to
Quote:To avoid matrix arithmetic problems in some renderers, the third dimension ({y} in the default orientation) of two-dimensional primitives must be given a non-zero scaling factor.There is no reason to restrict this value to 1, the only point is to avoid a non-degenerated transformation matrix.
