Full Version: Technic 2016
Pages: 1 2 3 4 5
[Image: 42056.jpg]
Download MPD (OMR compliant)
Known errors: Missing stickers. Patterned parts replaced by plain parts (except for wheel arches)
Done with LDCad 1.6 alpha x
(edit) MPD updated: Corrected unrealistic gear shift paddle position (thanks Blakbird!), and fixed two wrong flex axles on rear.
[Image: 42055.png]
Nice work! Must've cost a lot of time.
I'll add it to the omr site when it's up again  Wink
(2016-08-29, 20:25)Merlijn Wissink Wrote: [ -> ]Nice work! Must've cost a lot of time.
Well, not sooo long. Lots of parts, yes, but structure is relatively simple (few time consuming weird angles / flex parts)
Updated again to correct ajar engine cover (thanks again to Blakbird for noticing!)
[Image: 42054.jpg]
Done with LDCad 1.6 alpha 4
Edit: updated to add missing flex axle!
Very nice.
I try to import this into Blender but the LDR-importer doesn't support MPD. I tried a method to export this again with MLCad but it will merge the new parts into one model with a black material.
Question: is it possible to convert a MPD into a LDR what the Blender script can import without errors?
OK, I found MPDCenter and it exported a straight LDR file I am importing now.
[Image: 29329177870_192a3b9aab_o.jpg]
[Image: 29584911506_c38206313e_o.jpg]
Nothing to say but Wow!!!
Pages: 1 2 3 4 5
