2015-11-24, 13:54
Hello,
after three months I am proudly releasing LDPartEditor 0.8.3b
You can download LPE from this page:
Changelog:
This release includes 10 important bug fixes as well.
The program was tested intensively with "real world" files. Especially, "Undo" and "Redo" should work now fine.
Please note that this software is in the beta stage. Although, LPE 0.8.3b was carefully tested and developed, there are already known issues for this release. There is a potential risk of data loss.
Something can go wrong in about 100.000 lines of code.
LPE is a 3D CAD application: The overall system requirements are higher. While I recommend to use a powerful 64-bit multicore system, it could be possible, to run LPE on older machines as well.
System Requirements:
Minimum System Requirements:
Recommended Requirements:
In general, I recommend to install the 64-bit version of the JVM.
edit: I put two releases in one post (0.8.3 and 0.8.3b)
Changelog:
- ...configure shortkeys
- ...experience a faster program start.
- ...auto-detect and fix T-Junctions
- ...show the text line selection in the 3D editor as a selection (if the 3D editor is opened)
- ...enable Single Vertex Modification (aka SyncEdit) in the Text Editor when you select one vertex in the 3D Editor.
- ...benefit from a little performance gain (due to some modifications related to logging in the debug mode).
- Download the zip-Archive
- On windows, double-click "run.bat" to start LPE.
- On linux/mac, you have to excecute the shell script "run.sh" to start LPE.
- Java Runtime Environment (JRE) 1.7
- RAM: 2.5GB
- Video-Memory: 512 MB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7, Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
- RAM: >4 GB
- Video-Memory: >512 MB
- Free Disk Space: 512 MB
java -d64 version
