2015-10-07, 21:29
I've played with the Lego Digital Designer, and like some aspects of it, and others drive me nuts. One thing that I like is that it does a pretty good job with snapping pieces together. I'm also playing with LDCad, which is awesome, but I'm noticing some weird behavior and I'm not sure if it's specific to LDraw or LDCad. Here's what I've noticed:
The "Technic pneumatic T-piece Type 2" (4697b) does not appear to snap to the "headlight" hole on the front of "Brick 1 x 1 with headlight" (4070). However, it works just fine on "Brick 1 x 1 with stud on one side" (87087). Also, 4697b snaps just fine to the front hole on "Brick 1 x 1 with studs on four sides" (4733), but will not snap to any of the other holes. This is regardless of the axis stepping that I choose.
Is this by design, or should it snap to any of the holes in any of the bricks I mentioned?
I'm using LDCad v1.4 and the latest version of LDraw library (not sure exactly how to find the version of that), but I installed it using the AIOI about a week ago.
