2015-07-17, 21:01
2015-07-18, 15:36
I'm on it. It is present in LDD, but I don't have it.
Do you have the part?
Is there a particular reason for the two flat spots on the underside of the hinges?
2015-07-18, 16:16
Fantastic! Thank you so much.
I do have the part. Do you need some photos?
To my knowledge there is no reason for the flat spots near the hinge.
2015-07-19, 8:25
2015-07-19, 9:16
Magnus Forsberg Wrote:I'm on it. It is present in LDD, but I don't have it.
I think the flat spots help keep it in the lowered and raised positions, respectively. I don't have the part though.
2015-07-19, 15:15
Yes. Those corners should line up.
2015-07-20, 9:38
OK, thanks.
It is now at the PT.
I had to move all three lines affected by those corners. Two vertical (left/right) lines and the lower horizontal line.
2015-07-20, 9:51
Yes, that was my first thought too.
It looks more like they have made an attempt to reduce the friction, if it were to come close enough.
But I can't find any part coming close enough, to work like that. Not even this contraption comes close. Used in at least 9 different models, together with this windscreen.
2015-07-20, 20:24
Awesome! You're the best! Thank you so much!
