Full Version: [LDPartEditor] 0.8.2 Beta Released
Hello,
I'm just releasing LDPartEditor 0.8.2 Smile I will try to release early and often!
[Image: attachment.php?aid=12753]
You can download LPE from this page:
  1. Download the zip-Archive
  3. On windows, double-click "run.bat" to start LPE.
  4. On linux/mac, you have to excecute the shell script "run.sh" to start LPE.
Please note that this software is in the beta stage. Although, LPE 0.8.2 was carefully tested and developed, there are already known issues  for this release. There is a potential risk of data loss.
  2. On linux/mac, you have to excecute the shell script "update.sh".
LPE is a 3D CAD application: The overall system requirements are higher. While I recommend to use a powerful 64-bit multicore system, it could be possible, to run LPE on older machines as well.
Changelog:
  • ...experience a faster program start.
  • ...use a wireframe render mode.
This release comes with 9 important bugfixes as well (including a fix for the french AZERTY keyboard).
System Requirements:
Minimum System Requirements:
  • Java Runtime Environment (JRE) 1.7
  • Operating System (32/64bit): Windows [XP; Vista; 7 or newer], Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
  • RAM: 2.5GB
  • Video-Memory: 512 MB
  • Free Disk Space: 100 MB
Recommended Requirements:
  • Operating System (64bit): Windows 7, Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
  • RAM: >4 GB
  • Video-Memory: >512 MB
  • Free Disk Space: 512 MB
java -d64 version
In general, I recommend to install the 64-bit version of the JVM.
With the release of 0.8.2b you will be able to...
...see and validate the log data before you upload it to the internet.
This minor release includes 1 important bug fix as well.
With the release of 0.8.2c you will be able to...
...correct 0 BFC CERTIFY INVERTNEXT, NOCLIP and CLIP meta commands (MLCAD bug)
...see dithered colours and convert dithered colour codes into direct colours.
I am currently completing a GUI translation feature to support the French and the German language.
An improved CSG triangulation algorithm is also on my list.
Next to custom shortkeys...
...and the possibility to show text line selection in the 3D editor as a selection...
...and to draw to cursor position in the text editor.
Thanks for this update Nils!
Having a cursor in the Text Editor will improve handling a lot.
What I would like to have is that when you select a vertex and do a "show in text editor", that the Text Editor switched to the "SyncEdit" mode and marked the locations where this vertex is used.
Gerald Lasser Wrote:What I would like to have is that when you select a vertex and do a "show in text editor", that the Text Editor switched to the "SyncEdit" mode and marked the locations where this vertex is used.
I created a user story for your request Smile
btw: The implementation of the algorithm which corrects T-junctions inside CSG bodies is done!!
Thanks!
Nils Schmidt Wrote:btw: The implementation of the algorithm which corrects T-junctions inside CSG bodies is done!!
That is great news! Looking forward to it! I stopped working on the hemisphere so looks I can pick it up again!
LDPE is compatible to Windows 10. I tested it on serveral "Windows Insider" builds and I got a full license for Windows 10 Professional N (64-bit).
As I said:
The CSG improvements are now "complete"! This task was a little bit hard... but take a look at the results Smile
Before improvement:
[attachment=1604]
After algorithm improvement (rectifier was triggered manually ):
[Image: improved_csg.png]
Thanks for your efforts! Really appreciate it!
Can I already use the update.bat to download?
Gerald Lasser Wrote:Can I already use the update.bat to download?
Not yet. I will require three more days to prepare the release (0.8.2d), as it comes with additional bug fixes and little performance improvements.
I would like to spend at least one day to test some things.
The CSG bugfix was not easy to solve. I needed a 30-day development break to get new energy for this task.
Hi ,
I'm just releasing LDPartEditor 0.8.2d Smile I will try to release early and often!
Please note that this software is in the beta stage. Although, LPE 0.8.2d was carefully tested and developed, there are already known issues  for this release. There is a potential risk of data loss.
Changelog:
  • ..benefit from improved CSG triangulation. The process is not free from errors, but in general a great improvement.
This release comes with 5 important bugfixes as well.
  • RAM: 2.5GB
  • RAM: >4 GB
java -d64 version
I'm getting nowhere! How do I move a vertices?
[Image: LDPE-2.jpg]
PS. I'm still unhappy with that STRG+MMB to move around in the 3d view. Would a SHIFT+STRG+RMB or LMB be possible?
Could someone please spell out the acronyms here...
MMB? STRG?
MMR=Middle mouse button
LMB=Left mouse button
RMB=Right mouse button
STRG= CTRL on a German keyboard
I am working now on a new feature for custom shortkey mappings.
If you want to move a vertex, which is connected to adjacent lines, triangles or quads, you have to enable "Move Adjacent Data". It's the "A" button next to "Show All".
You can use keys on the keyboard, instead of mouse keys.
'K' emulates a left mouse button in the 3D editor.
'M' emulates a middle mouse button in the 3D editor.
'L' emulates a right mouse button in the 3D editor.
