2015-05-31, 23:11
Hello,
I'm just releasing LDPartEditor 0.8.1d Beta...
Unfortunately, the included updater was broken.
Older versions are not able to search for updates newer or equal to version 0.8.1d.
You can download LPE 0.8.1d only from this page:
Please note that this software is in the beta stage. Although, LPE 0.8.1d was carefully tested and developed, there are already known issues for this release. There is a potential risk of data loss. LPE could endanger your system stability, too.
You can search for updates (in the future) if you do the following steps:
LPE is a 3D CAD application: The overall system requirements are higher. While I recommend to use a powerful 64-bit multicore system, it could be possible, to run LPE on older machines as well.
Changelog:
This release includes important bug fixes as well.
System Requirements:
Minimum System Requirements:
Recommended Requirements:
In general, I recommend to install the 64-bit version of the JVM.
- Download the zip-Archive
- On windows, double-click "run.bat" to start LPE.
- On linux/mac, you have to excecute the shell script "run.sh" to start LPE.
Changelog:
- ...use a new program updater.
- Java Runtime Environment (JRE) 1.7
- RAM: 2.5GB
- Video-Memory: 512 MB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7, Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
- RAM: >4 GB
- Video-Memory: >512 MB
- Free Disk Space: 512 MB
java -d64 version
