2015-05-31, 13:27
Hello,
I'm just releasing LDPartEditor 0.8.1c Beta
I will try to release a new version each month or earlier.
You can download LPE from this page:
Please note that this software is in the beta stage. Although, LPE 0.8.1c was carefully tested and developed, there are already known issues for this release. There is a potential risk of data loss. LPE could endanger your system stability, too.
LPE is a 3D CAD application: The overall system requirements are higher. While I recommend to use a powerful 64-bit multicore system, it could be possible, to run LPE on older machines as well.
Changelog:
This release includes bug fixes as well (thanks to Willy for sending me his log files).
System Requirements:
Minimum System Requirements:
Recommended Requirements:
In general, I recommend to install the 64-bit version of the JVM.
- Download the zip-Archive
- On windows, double-click "run.bat" to start LPE.
- On linux/mac, you have to excecute the shell script "run.sh" to start LPE.
Changelog:
- ...emulate mouse keys on a focused 3D window with keyboard keys (K = Left Mouse Button, L = Right Mouse Button, M = Middle Mouse Button)
- ...Convert selected Lines to Conditional Lines
- ...use a even better "Delete" function in the parts tree (it creates .bak files for project parts and deletes only the reference path to non-project parts).
- Java Runtime Environment (JRE) 1.7
- RAM: 2.5GB
- Video-Memory: 512 MB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7, Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
- RAM: >4 GB
- Video-Memory: >512 MB
- Free Disk Space: 512 MB
java -d64 version
