2015-05-25, 19:53
Hello,
I'm just releasing LDPartEditor 0.8.1b Beta
I will try to release a new version each month or earlier.
You can download LPE from this page:
Please note that this software is in the beta stage. Although, LPE 0.8.1b was carefully tested and developed, there are already known issues for this release. There is a potential risk of data loss. LPE could endanger your system stability, too.
LPE is a 3D CAD application: The overall system requirements are higher. While I recommend to use a powerful 64-bit multicore system, it could be possible, to run LPE on older machines as well.
Changelog:
This release includes many bugfixes as well.
System Requirements:
Minimum System Requirements:
Recommended Requirements:
In general, I recommend to install the 64-bit version of the JVM.
- Download the zip-Archive
- On windows, double-click "run.bat" to start LPE.
- On linux/mac, you have to excecute the shell script "run.sh" to start LPE.
Changelog:
- ...(you won't be able to) delete your parts physically from the harddisk anymore
- ...use the background image feature.
- ...benefit from better icon design.
- ...choose your locale.
- ...convert optional lines to edge lines.
- ...manipulate the subfile matrix numbers without the text editor.
- ...send error logs to me.
- ...use a coloured cross cursor.
- ...benefit from auto-reading the %LDRAWDIR% environment variable.
- Java Runtime Environment (JRE) 1.7
- RAM: 2.5GB
- Video-Memory: 512 MB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7, Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
- RAM: >4 GB
- Video-Memory: >512 MB
- Free Disk Space: 512 MB
java -d64 version
