2015-05-01, 18:56
I'm glad to introduce to all of you this release. This version have many changes, so answer only to some things which need attention posted by Willy Tschager. Download from https://github.com/Jeremy1980/licreator.
- The CC license should also be shipped as a .txt
- I included the CC license into COPYING file.
- The Toggle Assistent pop-up should have a closing button in the top right-hand corner as it is not obvious how to get rid off
- Model -> Toggle Assistent not accessible when no model is loaded while F1 works
- I handle this. Probably...
- Have the ability to export just one page as PDF (either current page or number)
- Right-Click on Page object. Select 'Render Me' option.
- Save in the folder where the model is stored. Currently they end up in my VirtualStore on Win7
- This looks like a problem with the configuration of your virtual machine, I can explain it in a separate thread.
- A pane which shows the LDraw code underneath
- It work realy amazing to me. Right click on Part List Page object. Choose 'Show design numbers'. If somethings go into wrong way. Then correct them with codes.ini file. Select Model => Check for Library Updates... to get latest version, that overwrite your actual file.
- Once you edit the template (I moved around the step number and the PLI) there is no menu entry to refresh the pages showing the new setting.
- Save/Load template somehow broken (the above change couldn't be save or loaded)
- Fix mistake. Template elements are no longer movable.
- Reopen produces a "Open Error"
- Fix mistake. Re-opening ability available only on saved instruction.
- LIC doesn't support Buffer-Exchange or MLCad Arrow code and should at least ignore them when it comes across.
https://www.dropbox.com/s/0tkc3m7tajo4s0q/LIC.jpg?dl=0
- Whole template concept should be out-sourced to a Menu -> Setting where you set up your defaults but have the ability to save/load a template if needed
- Too much work. Maybe one fine day -- it will become a reality.
- "Generate images with POV-Ray" grayed out though I have defined all paths. Had to restart the prog twice to get it work
- Prog crashes on Export
- Handling QThread class to stop freezing application one some behaviors. Long and/or Lazy work now out of main thread. I hope this correct solution. Probably...
- I do not think that L3P is a good choice as POV-Exporter. I like the output of LDView much better - and easier to handle.
- You probably have right. But actually stay AS IS. Do not forget to set L3PAccessLog or POVAccessLog on True to know what these programs are doing.
