Full Version: New Parts for LGEO Library
Pages: 1 2 3 4 5 6
I also tried radiosity, but with multiple light sources. This didn't worked our very well. With only on light source, I've got nice results.
I experimented with radiosity allready in the beginning, but I didn't came to a good result. With the new settings it feels promising so far. I'll start over render everything again, because of better results. I expect less problematic parts, since the problem with the faces seems to be solved now Smile.
So Long
Sven
Hi Damien,
I'd like to send you a PM, but can't find something like this in this foum. Is there a way how I can contact you?
So long
Sven
damien___(at)hotmail.com
Update: 2016/02/28
[Image: v25-1.jpg]
286: Minifig Suitcase Joiner Tab
336: Technic Pneumatic Cylinder 2 x 2 Piston Rod 5.5L
337: Technic Pneumatic Cylinder 2 x 2 Piston Rod 4L
757: Hose Flexible 12L Top 1 x 1 x 2/3 with Stud
2435: Plant Tree Pyramidal 3 x 3 x 4
2437: Windscreen 3 x 4 x 1 & 1/3
2489: Barrel 2 x 2 x 1.667
3003p0a: Tile 1 x 8 with White Winged Lion Pattern
3081a: Window 1 x 2 x 2 Classic with Solid Studs
3081ac01: Window 1 x 2 x 2 Classic with Solid Studs (Complete)
3081b: Window 1 x 2 x 2 Classic with Long Sill
3081bc01: Window 1 x 2 x 2 Classic with Long Sill (Complete)
3081c: Window 1 x 2 x 2 Classic with Short Sill
3081cc01: Window 1 x 2 x 2 Classic with Short Sill (Complete)
3082: Window 1 x 2 x 2 Classic Glass
3587: Tail 2 x 5 x 3.667 Plane
3626bpw1: Minifig Head with Thick Moustache, Angry Eyes, Wavy Mouth, Long Hair and Stubble Pattern
3626c: Minifig Head with Closed Hollow Stud
3861: Door 1 x 4 x 5 with Panes
3899: Minifig Cup
4162p10: Tile 1 x 8 with "Venice" Pattern
4449: Minifig Suitcase
4449c01: Minifig Suitcase Open
4466: Exhaust Pipe Twin Inlet 11L Left
4467: Exhaust Pipe Twin Inlet 11L Right
4528: Minifig Frypan
4617: Propellor 3 Blade 5.5 Diameter with Technic Peghole
4617a: Propellor 3 Blade 5.5 Diameter with Freestyle Pinhole
4617b: Propellor 3 Blade 5.5 Diameter with Technic Peghole
14417: Plate 1 x 2 with Ball Joint-8
14769p06: Tile 2 x 2 Round with Round Underside Stud with Black and Dark Bluish Grey Grid Pattern
22961: Technic Axle with Perpandicular Pin Hole
32474: Technic Ball Joint with Axlehole Blind
42610: Wheel Rim 8 x 11.2 with Centre Groove
44674: Car Mudguard 3 x 4 Overhanging
49668: Plate 1 x 1 with Tooth In-Line
50943: Car Engine 2 x 2 with Air Scoop
56890: Tyre 12/57 x 10 Balloon
62361: Car Mudguard 6 x 1.5 x 1 with Arch
88393: Brick 1 x 2 x 5 with Groove
90398: Minifig Statuette
92690: Bar 1L with Top Stud and Two Side Studs
821472hc01: Sticker 1.0 x 2.8 with Black and Light Grey Grid on Transparent Background (Right) (Formed)
821472ic01: Sticker 1.0 x 2.8 with Black and Light Grey Grid on Transparent Background (Left) (Formed)
Update: 2017/04/05
[Image: v26-1.jpg]
2572: Panel 6 x 6 x 9 with Curved Top
2578b: Brush Holder Street Sweeper with Hinge Bottom
3069bp01: Tile 1 x 2 with Letter Pattern
3935: Wing 4 x 4 Right
3936: Wing 4 x 4 Left
4162p11: Tile 1 x 8 with "Berlin" Pattern
4162p12: Tile 1 x 8 with "New York City" Pattern
4162p13: Tile 1 x 8 with "United States Capitol Building" Pattern
4162p14: Tile 1 x 8 with "Buckingham Palace" Pattern
4865bp01: Panel 1 x 2 x 1 with Rounded Corners with Brick Wall and Tunnel Pattern
4865bp02: Panel 1 x 2 x 1 with Rounded Corners with Light Blue Sky and Grey Skyline Pattern
4865bp03: Panel 1 x 2 x 1 with Rounded Corners with Light Blue and Green Arrows on Tan Background Pattern
6027: Animal Dragon Head
6028: Animal Dragon Tail
6141: Plate 1 x 1 Round
6184: Arch 1 x 12 x 5 with Curved Top
18674: Plate 2 x 2 Round with 1 Centre Stud
21229: Fence Spindled 4 x 4 x 2 Quarter Round with 3 Studs
30044: Window 1 x 2 x 2.667 with Rounded Top
30046: Window 1 x 2 x 2.667 Pane Lattice Diamond with Rounded Top
30056: Fence Spindled 4 x 4 x 2 Quarter Round with 2 Studs
30167: Minifig Hat Wide Brim Flat
43719: Wing 4 x 4 with 2 x 2 Cutout
51011: Tyre 6.4/75 x 8 Shallow Offset Tread
51739: Wing 2 x 4
60849: Minifig Hose Nozzle with Side String Hole Simplified
86500: Dome 4 x 4 Smooth
87617: Cylinder 1 x 1 x 4.333 with Handle
88293: Brick 3 x 3 x 2 Round Corner with Dome To
92947: Brick 2 x 2 Round with Grille
99780: Bracket 1 x 2 - 1 x 2 Up
99781: Bracket 1 x 2 - 1 x 2 Down
Update: 2017/09/03
[Image: v27-1.jpg]
2431pz0: Tile 1 x 4 with Black Utility Belt Pattern
2431pz1: Tile 1 x 4 with Black and Light Yellow Triangle on Red Rectangle Pattern
2599: Minifig Flipper
3003p0b: Tile 1 x 8 with Gold and White Big Ben Clock Face Pattern
3004pz0: Brick 1 x 4 with Bright Green Tie with Bright Light Orange Skulls Pattern
3010pz0: Brick 1 x 4 with Batman Logo in Yellow Oval Pattern
3010pz1: Brick 1 x 4 with Yellow Batgirl Logo with Black Border Pattern
3010pz2: Brick 1 x 4 with Yellow Colar and Yellow Robin Logo Pattern
3010pz3: Brick 1 x 4 with Black Line, Light Orange Skull and Magenta Pockets Pattern
4162p15: Tile 1 x 8 with "THE SOLOMON R GUGGENHEIM" Pattern
4162p16: Tile 1 x 8 with "Sydney" Pattern
4162p17: Tile 1 x 8 with "Chicago" Pattern
4162p19: Tile 1 x 8 with "London" Pattern
11090: Bar Tube with Clip
11208: Wheel Rim 10 x 14 with Fake Bolts and 6 Spokes
11458: Plate 1 x 2 with Offset Peghole
11476: Plate 1 x 2 with Clip Horizontal on Side (Thick C-Clip)
11477: Slope Brick Curved 2 x 1
15068p05: Slope Brick Curved 2 x 2 x 0.667 with "MUSEUM" Text Pattern
15070: Plate 1 x 1 with Tooth Perpandicular
15208: Plate 1 x 2 with 3 Teeth In-Line
15209: Tile 1 x 2 with 2 Teeth Vertical
15395: Dome 2 x 2 Inverted with Stud and Tube
15397: Plate 3 x 3 Cross
15571: Slope Brick 45 1 x 2 Triple with Bottom Stud Holder
18649: Plate 1 x 2 with Handles on Opposite Ends
18654: Technic Beam 1
18677: Plate 1 x 2 with Offset Peghole on Underside
18976: Wheel Rim 11 x 18 with Vented Disc Brake
22385: Tile 3 x 2 with Angled End
22388: Slope Brick 50 1 x 1 x 0.667 Quadruple
22885: Brick 1 x 2 x 1.667 with Studs on 1 Side
23443: Bar Tube with Handle
23950: Panel 1 x 3 x 1 with Rounded Corners
24246: Tile 1 x 1 with Rounded En
24299: Wing 2 x 2 Left
24307: Wing 2 x 2 Right
24309: Slope Brick Curved 3 x 2
25269: Tile 1 x 1 Corner Round
25866c02: Figure Friends Lipstick with White Handle
26603: Tile 2 x 3
26604: Brick 1 x 1 with Studs on Two Adjacent Sides
30340: Minifig Life Ring
32294: Technic Suspension Arm 1 x 9 x 2.5
45677: Wedge 4 x 4 x 0.667 Curved
48729b: Bar 1.5L with Clip with Truncated Sides and Hole in Shaft
50745: Car Mudguard 4 x 2.5 x 2
50950: Slope Brick Curved 3 x 1
50990a: Dish 10 x 10 Inverted with Hollow Studs
50990b: Dish 10 x 10 Inverted with Solid Studs
55707c: Minifig Batarang
61409: Slope Brick 18 2 x 1 x 2/3 Grille
61678: Slope Brick Curved 4 x 1
64727: Bar 0.5L with Blade 3L
86208: Minifig Torch without Grooves
87079pz0: Tile 2 x 4 with Groove with Brickheadz Series Number "1"
93606: Slope Brick Curved 4 x 2
95108: Friends Lipstick Handle
95109: Friends Lipstick Core
98138: Tile 1 x 1 Round with Groove
98138p07: Tile 1 x 1 Round with Eye Pattern
98138pz0: Tile 1 x 1 Round with Two White Squares Pattern
99774: Minifig Ski 4L without Hinge
Update: 2018/02/05
[Image: v28-1.jpg]
11209: Tyre 10/32 x 14
11291: Wedge 3 x 4 x 0.666 Cutout
18977: Tyre 11.2/28 x 17.6 Intermediate
2431pz2: Tile 1 x 4 with Black Lines and Medium Azure and White Half Circle Pattern
2431pz3: Tile 1 x 4 with Black Moustache Pattern
25214: Cylinder 2 x 2 Elbow with Axle Holes
2530: Minifig Sword Cutlass
30028: Tyre 8/40 x 8 Slick Smooth
30031: 30031: Minifig Handlebars
3004pz1: Brick 1 x 2 with Collar and Tan Skin Pattern
3010pz4: Brick 1 x 4 with 3 Dark Red Vertical Stripes Pattern
3010pz5: Brick 1 x 4 with Silver Star and 2 Belt Buckles Pattern
3010pz6: Brick 1 x 4 with Black Pectoral SPAM CONTENT Pattern
3010pz7: Brick 1 x 4 with Black Abdominal SPAM CONTENT Pattern
3069bpz0: Tile 1 x 2 with Black Lines and Medium Azure and White Circles Pattern
3069bpz1: Tile 1 x 2 with Silver Rectangles and Medium Azure Trapezoid Pattern
3069bpz2: Tile 1 x 2 with 3 Dark Red Waves Pattern
3070bp00: Tile 1 x 1 with White Top Square Pattern
3176: Plate 3 x 2 with Hole
32014: Technic Angle Connector #6 (90 degree)
32015: Technic Angle Connector #5 (112.5 degree)
32016: Technic Angle Connector #3 (157.5 degree)
32034: Technic Angle Connector #2 (180 degree)
32192: Technic Angle Connector #4 (135 degree)
3245a: Brick 1 x 2 x 2
3245b: Brick 1 x 2 x 2 with Inside Axleholder
3245c: Brick 1 x 2 x 2 without Understud
3245cpz0: Brick 1 x 2 x 2 without Understud with Black, Silver and Red Jacket Pattern
3299: Slope Brick 33 2 x 4 Double
3622pz0: Brick 1 x 3 with Dark Red Lines, Brown Belt and Dark Nougat Buckle Pattern
3749: Technic Axle Pin
40379: Animal Tail Section End
4083: Bar 1 x 4 x 2 with Studs
42446: Bracket 1 x 1 - 1 x 1
43720: Wedge 4 x 2 Sloped Right
43721: Wedge 4 x 2 Sloped Left
43857: Technic Beam 2
50946: Car Grille 2 x 2.5 x 3 with Sloped Front
6005: Arch 1 x 3 x 2 with Curved Top
62360: Windscreen 3 x 6 x 1 Curved
6536: Technic Cross Block 1 x 2 (Axle/Pin)
6562: Technic Axle Pin
75902: Minifig Shield Round Bowed
75902p02: Minifig Shield Round Bowed with Bullseye with Star Pattern
87079pz1: Tile 2 x 4 with Groove with White "A" and 4 Black Lines Pattern
88930: Slope Brick Curved 2 x 4 with Underside Studs
88930pz0: Slope Brick Curved 2 x 4 with Black Line and Dark Red Rectangle Pattern
I am rendering an old LGEO scene, but with your new parts library. When I try to render the scene it quits when it asks for "lg_2582_slope" which it can't find. Do you know what might be the issue? Thanks.
//// Part 2582.dat
#ifndef (_2582_dot_dat)
#if (L3Quality > 0)
    #ifndef (lg_2582)
        #include "lg_2582.inc"
    #end
#end
#declare _2582_dot_dat = #if (L3Quality = 0) box { <-40,-4,-30>, <40,72,10> } #else object {
// Hinge Panel  2 x  4 x  3 & 1/3
    lg_2582
    transform L3LgeoToLDraw
#end
#declare _2582_dot_dat_clear = #if (L3Quality = 0) box { <-40,-4,-30>, <40,72,10> } #else object {
    lg_2582_clear
#end
#if (L3Quality > 0)
#declare _2582_dot_dat_slope = object {
    lg_2582_slope
#end
#end // ifndef (_2582_dot_dat)
The model was generated using L3P.exe.
(2018-02-07, 12:44)Michael Horvath Wrote: [ -> ]I am rendering an old LGEO scene, but with your new parts library. When I try to render the scene it quits when it asks for "lg_2582_slope" which it can't find. Do you know what might be the issue?
It might be a typo in my files, I will investigate and let you know asap.
(2018-02-07, 14:00)Damien Roux Wrote: [ -> ]
OK, I see the problem.
Historically LGEO considers 2582 as a "slope" part, with a grainy surface.
Apparently I didn't consider it as a "slope" part.
The question is : has that part a grainy surface or not?
I can't answer as I don't own it.
After a few search on the web, I would say that this part is not grainy.
Only a pattern version is.
[Image: s-l1600.jpg]
If someone can confirm this, that would be great.
(2018-02-07, 18:42)Damien Roux Wrote: [ -> ]OK, I see the problem.
Apparently, it is not that simple. For example this one has a pattern and is not grainy (I own this part!), but it is transparent.
And this one is not transparent and is also not grainy.
(2018-02-07, 19:54)Nils Schmidt Wrote: [ -> ]Apparently, it is not that simple. For example this one has a pattern and is not grainy (I own this part!), but it is transparent.
Thanks Nils for the info.
So from what I undestand, only some patterns are grainy, and obviously, the unpatternd part is not, so I would say that my version is correct.
So you have two solutions for you render:
- use my LGEO.xml file, use my package, recreate the .pov file from ldview
- use my package, keep your existing L3P generated .pov file, remove all lg_2582_slope related stuff from your .pov file (if you can give me the entire .pov file I can do it for you).
BTW, are you still using L3P or are you only trying to rerender an old file?
FYI
Part `lg_4070` asks for `lego_logo_text`, but this object is only created if the quality level is higher than 2. I think there needs to be a check for quality level inside the part.
[edit]
Part `lg_4083` does this too
I have a bunch of old scenes made with L3P.
I think the bigger problem WRT the sloped part needs to be solved by LDraw parts authors. IMO there should be one digital part per real part, including the graininess, but ignoring differences in color.
FYI
Three parts expect there to be a `LG_INNER_CORNER_SPACE` variable, but it seems not to be defined anywhere.
The parts are:
lg_2959.inc
lg_33291.inc
lg_91049.inc
FYI
Two parts expect there to be the objects called `lg_tech_knob_join` and `lg_tech_knob_join_clear`, but they are not defined anywhere. These parts are:
lg_33291.inc
lg_macro.inc
(2018-02-09, 1:21)Michael Horvath Wrote: [ -> ]FYI
[edit]
Thanks for that!
As I never render without Logo, I've never notice that.
The Package has been updated, you shouldn't get the problem anymore.
(2018-02-09, 1:56)Michael Horvath Wrote: [ -> ]FYI
The parts are:
lg_2959.inc
lg_33291.inc
lg_91049.inc
As my libraby conflicts with Owen's one, those parts are giving problems.
I have reworked them, so the problem shouldn't be there anymore.
They will be "officially release" on my next update, but they are already in the package, so you can download it.
(2018-02-09, 2:00)Michael Horvath Wrote: [ -> ]FYI
lg_33291.inc
lg_macro.inc
33291 is OK (see my previous post).
But there are still 20 parts (made by Owen) that use the "lg_macro.inc" file, so they will give problems until I rework them. Hopefully on next update.
(2018-02-10, 0:25)Damien Roux Wrote: [ -> ]
lg_33291.inc
lg_macro.inc
Thanks so much for your hard work!
I have the following folders filled with LGEO parts:
lg_lutz - Lutz Uhlmann, http://www.digitalbricks.org/lgeo.html (dead link)
lg_lgeofix - Lars C. Hassing, http://www.hassings.dk/l3/lgeofix.html
lg_owen - Owen Burgoyne, https://forums.ldraw.org/thread-6127.html
lg_darats - Damien Roux, http://www.eurobricks.com/forum/index.ph...pic=108739
stl_darats - Damien Roux, http://www.eurobricks.com/forum/index.ph...pic=108739
Do you see any potential conflicts from dumping them all into the same folder? Just as importantly, does your version LGEO.xml include all of these?
Thanks.
"lg_3794a.inc"
This part is listed in LGEO.xml, but I don't think the LGEO part was actually ever created. At least, I don't have a copy of the part, and it causes POV-Ray to stop parsing because it is missing.
[edit]
Same for "lg_2345p44.inc".
[edit]
"lg_4215a.inc" complains about missing object `lego_logo_text_clear` if `lg_quality` is less than 3.
(2015-04-30, 17:14)Willy Tschager Wrote: [ -> ]
Darats Wrote:My lgeo.xml was based on Owen's one I guess, but might not be up to date.
The one I'm currently sharing has my around 500 personnal LGEO parts in it, but as I'm cleaning the lg files one by one, I would say that my xml file will not be completely usable until I finish to release everything. Should be a matter of one or two weeks. I will make regular updates on the Eurobricks forum.
When everything will be done, I think yes, you could add it to the AIOI if the file size is OK. But before I need testers to make sure the parts are compatible with other computers.
No hurry on this. The AIOI usually ships in June and January. Consider the LDraw wiki as comune upload place for the lgeo.xml.
Which page in the wiki? Thanks.
(2018-03-02, 2:44)Michael Horvath Wrote: [ -> ]I have the following folders filled with LGEO parts:
Thanks.
I would say, yes my LGEO.xml include all of these but my lgdefs.inc is not compatible with Owen's part, so it will give errors until I've replaced all the problematic ones. As stated in my first post it is still WIP.
I am slowly trying to make it 100% OK but the work is quite huge, so it takes time.
When everything will be ready my package will be part of the ldraw AIOI.
I would say, make a copy of your current LGEO setup and give it a try!
(2018-03-02, 3:17)Michael Horvath Wrote: [ -> ]"lg_3794a.inc"
[edit]
[edit]
Thanks for the notice. I will investigate. But PovRay shouldn't crash because of LGEO.xml because it doesn't use it actually.
I do have a lg_3794a.inc file from original LGEO library. Maybe I have renamed it form lg_3794.inc, I don't know.
I will recreate that part for next update, so the problem will disappear.
lg_2345p44.inc is a part I forgot to include (for some reason), it will be fixed for next update.
lg_4215a.inc is fixed, you can already redownload the package to get it.
BTW, I'd like to thank you for pointing me all these mistakes, it helps a lot! Feel free to go on!
(2018-03-04, 0:17)Damien Roux Wrote: [ -> ]... When everything will be ready my package will be part of the ldraw AIOI. ...
Is that plan still on track or did you loose interest meanwhile?
Just asking because your last update of this thread is now nearly exactly one year old and I'm still looking forward to that official release.
You did such a great work up to that point and it would be a shame if it now just get abandoned.
Kind regards,
Tom
(2019-03-03, 14:45)Thomas Chen Wrote: [ -> ]Is that plan still on track or did you loose interest meanwhile?
Kind regards,
Tom
Yes, this is still on tracks, just lacking time.
I have maybe 20 parts to rework and I'm done.
Then a few issues still prevents it to be officially release, maybe regarding compatibility with current LGEO library.
I cannot give a date but I will try to get back to work to complete it soon.
(2019-03-03, 22:09)Damien Roux Wrote: [ -> ]Yes, this is still on tracks, just lacking time.
Hey Damien,
thank you very much for your quick and positive reply.
I'm looking forward to it.
Kind regards,
Tom
I've created a GitHub repository for LGEO. You are welcome to contribue what you have there. PM me and I can give you admin rights.
(2019-03-07, 16:40)Orion Pobursky Wrote: [ -> ]I've created a GitHub repository for LGEO. You are welcome to contribue what you have there. PM me and I can give you admin rights.
I've PMed you bu5t got no answer yet.
(2019-03-19, 0:38)Damien Roux Wrote: [ -> ]I've PMed you bu5t got no answer yet.
I got it. I’ve just been a bit swamped IRL. I’ll try figure out what we want to do and get back to you very soon.
What is the status of this repo? Is it "up to date" with newer parts as well as Darat's parts? Is it public or private?
(2019-06-12, 5:40)Michael Horvath Wrote: [ -> ]What is the status of this repo? Is it "up to date" with newer parts as well as Darat's parts? Is it public or private?
There is no status. It doesn't exist because I dropped the ball on this.
(2019-06-12, 12:48)Orion Pobursky Wrote: [ -> ]There is no status. It doesn't exist because I dropped the ball on this.
Oh, that's too bad. I've collected a lot of parts, but can't always remember which person's parts need to be applied first and which need to be applied last (and override the others). I would rather just periodically download them all from ldraw.org.
(2019-06-13, 2:56)Michael Horvath Wrote: [ -> ]Oh, that's too bad. I've collected a lot of parts, but can't always remember which person's parts need to be applied first and which need to be applied last (and override the others). I would rather just periodically download them all from ldraw.org.
I haven't forgotten about this, it's priority just lowered a few notches.
(2019-06-13, 2:57)Orion Pobursky Wrote: [ -> ]I haven't forgotten about this, it's priority just lowered a few notches.
Is there any licensing issue? Or is it not an issue? Just curious, thanks.
(2018-02-07, 21:29)Damien Roux Wrote: [ -> ]Thanks Nils for the info.
Sorry for the late reply.
Instead of removing the part from the model, do you maybe mean replacing the part with something else? I don't want a hole to appear in my model where a missing part is supposed to be.
I must admit that I don’t remember what I meant...
Am I correct in noticing that the AIOI now includes Owen's and Darat's parts?
(2019-06-19, 7:08)Michael Horvath Wrote: [ -> ]Am I correct in noticing that the AIOI now includes Owen's and Darat's parts?
I don't think my parts are part of the AIOI (if they do, 'm not aware of it), but Owen's ones are.
(2019-06-19, 19:30)Damien Roux Wrote: [ -> ]I don't think my parts are part of the AIOI (if they do, 'm not aware of it), but Owen's ones are.
My mistake, sorry! I have too much stuff on my computer I can't keep track of everything.
Is this what you are talking about?
https://github.com/billthefish/LDrawPOV
I also have a github account, as well as spreadsheets for keeping track of what LGEO parts have been released and by whom. (Maybe a little out of date, but shouldn't take long to update.) What I am not sure about are copyrights to redistribute LGEO parts. The individual parts just say "for private non-commercial use only" which is insufficient.
(2019-06-27, 13:36)Michael Horvath Wrote: [ -> ]Is this what you are talking about?
No, that was a side project of mine from many years ago. The goal was to create a library that was entirely CSG with no meshes. It was going to be supported by L3P 1.4 but since L3P 1.4 was never officially released this project never really took off.
(2019-06-27, 15:22)Orion Pobursky Wrote: [ -> ]No, that was a side project of mine from many years ago. The goal was to create a library that was entirely CSG with no meshes. It was going to be supported by L3P 1.4 but since L3P 1.4 was never officially released this project never really took off.
I'm pretty sure LDView's POV export supports it.
(2019-06-28, 3:32)Travis Cobbs Wrote: [ -> ]I'm pretty sure LDView's POV export supports it.
Enable "Search for POV replacements for LDraw parts" in the "Native POV Geometry" section of LDView's POV export settings, then make sure the inc files are in <LDrawDir>/pov/p or <LDrawDir>/pov/parts. Then as long as the filenames match the dat filenames (with .inc instead of .dat), it should work.
Is the SourceForge repo any different from the GitHub repo?
(2019-06-28, 10:26)Michael Horvath Wrote: [ -> ]Is the SourceForge repo any different from the GitHub repo?
No. I converted it to a github repo along with my other (stale) projects since I'm not the biggest fan of SF's interface right now.
I know I have discussed this in the past, but neither I nor Google can locate that discussion.
Anyway, several parts reference an object called "lg_tech_tube", but it is not defined anywhere in the LGEO files. Does anyone know what this object is and where to locate it?
Pages: 1 2 3 4 5 6
