I hope that these may be the last parts to complete 76042 Helicarrier.
90498pb02 Tile 8 x 16 with Bottom Tubes with Runway and SHIELD Logo Pattern
90498pb03 Tile 8 x 16 with Bottom Tubes with Runway Pattern
If someone has the sticker for 76042 Helicarrier, make it ldr part and upload, please.
Thanks you very much
Oscar
Do you or anybody has a good hi-res scan of the stickersheet? something like 600 dpi at least would be nice, 1200 dpi is perfect. There are some on Flickr, which are better than nothing...
Thansk
Thanks for those! Surprising to see how the "big 64" sticker looks... I took it in the meantime from the review at Brickset but those colors are completely off...
What is the actual color with the SHIELD Eagle? Light BLue?
Gerald Lasser Wrote:What is the actual color with the SHIELD Eagle? Light BLue?
Maybe it is distorted by scanning, but the real color is Medium Blue.
Edit: the inverted one uses the same colors of cause.
All stickers (except the description) for the helicarrier are on the PT, look for the number of the sticker sheet "6115204"
Isn't this one of the "d" or "e" sticker?
Anyway I wonder why "a" is missing...
I did the naming in a different way than the pictures which are attached to Christian's post.
a: the UCS plaque (G in Christian's post) I did not do it (yet) as it is a hell of work
b: is the large sticker with the 64 Pattern and the tons of rivets.. (C in Christian's post)
c: is the smaller "64" Sticker (D in Christian's post)
d/e: the two SHIELD logos (A/B in Christian's post)
f/g: The runway portions.
I am not sure about the font of the plaque. It looks to be just a simple Calibri, with a modified "1" everything else looks fine.
The pictures in my post are named in no special order. Just as i cut them from the scanned image.
BTW, there is no real guideline for this. Perhaps it makes sense to use the same sequence as the stickers are used in the instructions, but really... seems of minor importance :-)
