Thanks. I hadn't been on the board in a couple of days, and all sorts of stuff happens. I believe I have fixed this bug in my development code. Please try the LDView.exe inside
this zip.
Note: while I wouldn't have posted the above link if I didn't want people to use it,
please be aware that it is a development build based on my development source tree, and as such has
not received nearly the amount of testing that an official release gets. So feel free to use it, and even report bugs you find in it, but if you do report bugs, be sure to include the full version number in the bug reports.
Hi Travis,
I suspect your current code may still have problems because it will shift the sticker (since ay will be negative). I think the version of the macro I post will avoid this. Or the below.
#macro LDXSeamMatrix(Width, Height, Depth, CenterX, CenterY, CenterZ)
#local aw = 0;
#local ah = 0;
#local ad = 0;
#local ax = 0;
#local ay = 0;
#local az = 0;
#if (Width != 0)
#local aw = 1-LDXSW/Width;
#end
#if (Height != 0)
#local ah = 1-LDXSW/Height;
#end
#if (Depth != 0)
#local ad = 1-LDXSW/Depth;
#end
#if (Width != 0 & CenterX != 0)
#local ax = LDXSW/(Width / CenterX);
#end
#if (Height != 0 & CenterY != 0)
#local ay = LDXSW/(Height / CenterY);
#end
#if (Depth != 0 & CenterZ != 0)
#local az = LDXSW/(Depth / CenterZ);
#end
#if (aw <= 0)
#local aw = 1;
#local ax = 0;
#end
#if (ah <= 0)
#local ah = 1;
#local ay = 0;
#end
#if (ad <= 0)
#local ad = 1;
#local az = 0;
#end
matrix <aw,0,0,0,ah,0,0,0,ad,ax,ay,az>
#end
Thanks. I'll take a look at the source code once I get home, and update it accordingly. (I assume you're OK with me putting your macro code into LDView's source.)
Yes of course. Technically it's a derivative work of your macro so GPLd anyway.
Here is a build that contains Tim's fix for my fix.
Travis,
I have an XP machine on which recent LDView versions crash (regular 4.1 works). I can launch it, open a file or use drag and drop on the opened LDView. But if I use "open with" or launch from LDDP, I get a crash (exception code 0xc000005, Flags=0, record=0, address=0). Windows diagnostic is not more detailed, but if I can help to locate this issue...???
Clearing the registry doesn't help - actually it's worse since I can't even open LDView.
I'll contact you via email.
