2015-03-09, 13:34
Now you can download new version of LEGO Instruction Book Creator at https://code.google.com/p/licreator/
Please, share you comments here. In next version one wish per person will be graded**. I you put more that one I selected only one - randomly. This list will be closed at May 20, 2015 at 20:20
** maximally 10 in total. If I can do it.
Changes related to previous 0.8.501 version Wrote::: Set minimum size of width and height of application
:: Assistant now display properly
:: Fixed group of miscellaneous bugs
:: Key TAB can now work in loop
:: Added ability to re-opening current Instruction book
:: Disable real-time preview for speed-up and avoid crash situation
:: Added the ability to positioning the preview of sub-model from then menu
:: LicColor class can now use colors from LDConfig.ldr file
:: Remember now latest import location
:: Re-organize configuration file
:: Added switch options to monitoring L3P ,POV-Ray activities
:: Added option to restore data source of imported model
:: Added delimitation of the notification area for tool-tip and other
:: Added information about value of current zoom
:: Handling AttributeError exception for:
:: - getPartBoundingBox
:: - callGLDisplayList
:: - renderFinalImageWithPov
:: - updatePersistentIndices
:: Rewritten LicPovrayWrapper class
:: Provided information about license and author
:: Support of custom colors of user /0x, opaque; 0x02, opaque; 0x03, 50% Alpha/
:: Support of invisible color /0x07, 10% Alpha/
:: NOTICE: POV-Ray calls work only on instruction without submodels
