This is be my first step to know basic about rendering. So please, be polite to Me.
If I remove this then everything is generated fine
rotate <20.000000, 0, 0>
rotate <0, -45.000000, 0>
rotate <0, 0, 0.000000>
So how fix this file. Any idea ??
The rotates should be inside the object.
//// ModelObject 3741c01.dat
object { _3741c01_dot_dat material { L3Color15 }
instead of this
object { _3741c01_dot_dat material { L3Color15 } }
This is work. Thanks.
I will be consider why LIC generate this in this way.
And i have another problem:
Parameters
c:/ldraw/l3p.exe "c:/ldraw/PARTS/33078.dat" -c16 -sw0.5
"d:/workspace/eclipse/lic/src/dist/cache/30210 - Frodo with cooking corner.lic/POVs/33078_16.pov"
-bu -b1.0,1.0,1.0 -cg20,-45,0 -q3 -o
Result
[attachment=1513]
What is wrong in this !?
That's because l3p simply doesn't accept the 2 color codes 16 or 24 from LDConfig.ldr.
For that reason, my LDConfig.ldr is patched, and the 2 lines commented-out.
However, this of course has the effect that other tools which take the look of color 16 or 24 from
LDConfig.ldr have to fallback to their built-in default for those 2 colors.
I think at some day maybe l3p could be fixed to accept these 2 colors.
I read cheerfully LDConfig.ldr one again. THere are marked a LDraw Internal Common. So I take special care, to handle this situation.
