2015-02-08, 17:22
Hi all,
first of all, after a few years of not using MLCad, LPub, LSynth and so on I am back ;-) Thanks to everyone helping out here and providing the All-in-one-installer. That really helped me start off again.
My question:
I am creating an instruction for my little BR 80 Steamer with PowerFunctions – M motor, receiver, 2x PF lights and battery box all in one little engine. The first version of the instruction is done, you can find it at:
http://holgermatthes.de/bricks/data/inst..._small.pdf (~ 19 MB)
Now I have added PF lights and the cables using LSynth. If you insert the PF lights, you can not add all components of the lights in one step. So I had to splitt up:
#1 2x lights and some cable
#2 other parts
#3 middle 2x2 box and some cable
#4 other parts and receiver
#5 1x plug to the receiver and some cable
In LPub it shows the following in the part list per step:
#1 2x lights
#2 other parts
#3 middle 2x2 box
#5 1x plug
How can I force the programme that the part list of step #1 shows the complete PF lights (http://www.bricklink.com/catalogItem.asp?S=8870-1) and #3 and #5 do not show any further sub parts of the PF lights.
Same question shows up while adding the motor or the receiver and connecting them to another part in a later step.
I haven't found the complele PF lights, motors or receivers as one *.dat which I could use and Ghost them in MLCad. Then they should show up in the parts list per step in LPub? If so, how to get rid of the stand alone plugs or the middle box in the parts list? Can you Ghost parts from the parts list? The assembly should show the single element, but the part list should not show anything because the PF lights/motor/receiver was mentioned in an earlier step of the instructions.
Some with BOM: It should show the PF elements with cable and plug as one single element as you can buy them.
Thanks in advance for your help!
Holger
My question:
#2 other parts
#1 2x lights
#2 other parts
#3 middle 2x2 box
#5 1x plug
Holger
![[Image: 99499c01_71_1753_150_dpi_0.6_23_-45.png]](http://www.brickshelf.com/gallery/lg008823/CAD/99499c01_71_1753_150_dpi_0.6_23_-45.png)
