2015-02-10, 1:38
Roland Melkert Wrote:It's needed with things like the axlehole primitive if you keep track of 'slide' limits. The primitive it self is open ended but it might be used in e.g. a motor drive axle which is not (e.g. 71427c01).
Right - there's a modeling-level version of this if a user puts two poles (or other "inner" slider) mechanisms end to end and they don't come with stops...do they form one -big- slider?
The least insane thing I can think of is:
- The sliders should be marked as -not- being "stopped" on the end.
- Apps that have full physics won't limit movement - if you move a part up, it slides off of one pole and onto another.
- Apps that don't have full physics could still do a "merge" phase where they take all known connections in a rigid body and consolidate. Two end-to-end sliders become one big slider.*
Such mechanisms would work with axle primitives that represent segments of an axle.
But I can see a pretty valid counter-argument that this is crazy and a single connector should be annotated on the length of the axle.
cheers
Ben
* I am seriously considering this for Bricksmith - the idea is that given a set of joints connecting two bodies, we can run a 'reduce' operation where degrees of freedom are in conflict. So for example, a series of colinear ball joints become a single hinge, or a pair of parallel hinge-sliders lose their hinge action.
My hope would be that a lot of the times the number of degrees of freedom of a set of joints drops to zero (e.g. it's a rigid model, e.g. made of things like clips and bars) and I can simply merge the rigid bodies, resulting in fewer "live" joints.
