Following Darats idea exposed
here
Quote:I wasn't able to use chrd primitives cause there's no 1-16chrd.
So it doesn't look really nice with primitives substitution.
...I made a quick try: I copied 48/1-16chrd to p folder, removed the only quad it contains and inserted the file into Homer donut.
Here is the result with primitive substitution (1-16chrd was added only on top).
attachment=1385]
Comments?
Looks really nice. I've been so annoyed by those little gaps on the 1x1 tile (those are the only parts I've made prints for yet).
Would it be easy to fix all the other 1x1 round tiles?
Quote:Would it be easy to fix all the other 1x1 round tiles?
Yes, just add the attached file to your p folder, and following code to your part
1 16 0 0 0 9 0 0 0 1 0 0 0 9 1-16chrd.dat
1 16 0 0 0 8.31492 0 -3.44415 0 1 0 3.44415 0 8.31492 1-16chrd.dat
1 16 0 0 0 6.36396 0 -6.36396 0 1 0 6.36396 0 6.36396 1-16chrd.dat
1 16 0 0 0 3.44415 0 -8.31492 0 1 0 8.31492 0 3.44415 1-16chrd.dat
1 16 0 0 0 0 0 -9 0 1 0 9 0 0 1-16chrd.dat
1 16 0 0 0 -3.44415 0 -8.31492 0 1 0 8.31492 0 -3.44415 1-16chrd.dat
1 16 0 0 0 -6.36396 0 -6.36396 0 1 0 6.36396 0 -6.36396 1-16chrd.dat
1 16 0 0 0 -8.31492 0 -3.44415 0 1 0 3.44415 0 -8.31492 1-16chrd.dat
1 16 0 0 0 -9 0 0 0 1 0 0 0 -9 1-16chrd.dat
1 16 0 0 0 -8.31492 0 3.44415 0 1 0 -3.44415 0 -8.31492 1-16chrd.dat
1 16 0 0 0 -6.36396 0 6.36396 0 1 0 -6.36396 0 -6.36396 1-16chrd.dat
1 16 0 0 0 -3.44415 0 8.31492 0 1 0 -8.31492 0 -3.44415 1-16chrd.dat
1 16 0 0 0 0 0 9 0 1 0 -9 0 0 1-16chrd.dat
1 16 0 0 0 3.44415 0 8.31492 0 1 0 -8.31492 0 3.44415 1-16chrd.dat
1 16 0 0 0 6.36396 0 6.36396 0 1 0 -6.36396 0 6.36396 1-16chrd.dat
1 16 0 0 0 8.31492 0 3.44415 0 1 0 -3.44415 0 8.31492 1-16chrd.dat
Quote:What?! How?
Magic of LDView primitive substitution... The empty file is replaced with a mathematically defined arc (just as 48\1-16chrd does at 48 level).
What about officilizing this?
Truly magic.
Why does it only work correctly if I have the 'curve quality' slider set on an even value, 2, 4, 6..?
Odd values give the 4-4-torus and the 1-16chrd different number of 'corners'.
I usually have it set on 3.
Mmhhh... a bit annoying. Substitution polygon is level times 8, and the trick works only for multiple of 16 since main structure is 16-sided. Hence the need for even substitution level.
Could someone please check how MLCad copes with this empty file. I seem to recall that last time I tried something similar with an obsoleted part, MLCad whinged.
Otherwise, yes.
I'm not too sure what I think of this. I had to remove 'unnecessary' conditional lines from some of my shield parts because they only catered for LDView's smooth shading results so why should we have something like this around?
Indeed, this causes problems with MLCad. No whinge, but complete part is reduced to a single dot. It does work by adding a zero-sized triangle (attached) but this can perhaps cause issues with other programs (though I don't expect it).
