2014-11-04, 10:28
A couple of ground rules before you post:
Also, spec discussion previously happened in the Parts Authoring forum. Please search there for any previous threads and start a new thread here with a link back if you want to continue a previous discussion.
- If you have a gripe, suggest a way to fix it. Be specific.
- We will only consider breaking backwards compatibility for really good reasons. All suggestions need to keep that in mind.
- We are not going to covert the spec to XML, binary format, etc. (See above.)
- More detailed suggestions will most likely get more responses. Please avoid overly general suggestions
- Posts on this thread may get spun off into their own threads. If you're using the flat view (i.e. not threaded or hybrid), try not break threading.
