I recently built some new star wars models in LDraw. These models have some new parts which are not available so far. Unfortunately this new weapon “spring shooter” seems to be widely used now.
So I would highly appreciate to have the following parts:
#15400 Spring Shooter 1x4
#15303 Arrow 8M for Spring Shooter
#15100 Technic, Pin with Friction Ridges Lengthwise and Pin Hole (used in 75054 AT-AT)
Thanks and kind regards
Roland
Yes, I overlooked this post before answering the other... As I said, 15100 is an official part. Shooter and arrow are available in LDD and should be relatively easy to convert/adapt.
I'll do the shooter and arrow, but it will take a bit of time, I want to get one first.
Philippe Hurbain Wrote:Parts are there now http://www.ldraw.org/cgi-bin/ptscan.cgi?q=shooter
Still missing a shortcut with shooter + dart...
Now on Parts Tracker too!
Hi Philo, seems there is a tiny coloring bug in 15400, while the complete shooter is fine:
![[Image: coloring_bug_15400.jpg]](http://bricksafe.com/files/papacharly/coloring_bug_15400.jpg)
It doesn't seem to depend on the part itself. What editor/viewer are you using? Sometimes SR3D builder does weird things on shortcuts...
Philippe Hurbain Wrote:It doesn't seem to depend on the part itself. What editor/viewer are you using? Sometimes SR3D builder does weird things on shortcuts...
Yes, that's it: SR3D
Opening the same file in LDCad no problem occurs.
Well, it's a magical world ......
I think that SR3D behaves correctly on shortcuts if you first select color then add the part. Problems occur when you try to recolor after placing part.
When using a shortcut part in SR3D, it doesn't add the shortcut part, it adds all the parts in the shortcut. Personally, I find that quite annoying, because when opening it in another editor or software (such as lpub), you end up with all the loose parts...
I don't know if it's approapiate here, but you can select subparts in a shortcut part by holding shift and selecting a piece in the shortcut.
