2014-03-13, 13:29
I am trying to motorize my train so that I need to draw removing original parts for space to assmbler battery and receiver, I am not sure how to substrate parts from train, I only know how to add parts to train, can you help me?
Philippe Hurbain Wrote:Not simple, but you should be able to do that using BUFEXCHG. Can't tell much more, never tried myself...Thanks for your hint, I will try it.
Philippe Hurbain Wrote:Two possibilities:I have another idea, use brick with letter to spell word as a ldr part then insert to main, is this ok?
- generate text as LDraw parts using txt2dat tool. Pro: LPub source remains self contained. Con: can be tricky to orient the part not to get weird 3D look.
- Insert external images containing text (in lpub, edit -> add image). Simpler theoretically, better look easily achieved. But external images can be tricky to use especially for multi-step pages, lpub is notoriously buggy there.
Tim Gould Wrote:There's also the old school method of opening the files in a graphics editor (e.g. GIMP) and adding the text thereBut my instructions is in PDF format...
