2014-03-07, 20:39
I compiled LPub4 in Linux which runs fine. I render with LDView.
I used three version of LDView: a 4.2 under wine, a Linux-native 4.2 installed from the debs on sourceforge and a self-compiled Linux-native 4.2
Problems:
- with Wine-Version and Linux-natives I get different results by using the same args
- the problem seems to be the -ca and -ca arguments. Without it, both LDViews gave the same view on screen
- other arguments probably are not affected (but I didn't tested it a lot)
- the Linux-version-problem does happen both in the installed Ubuntu-deb and in a self-compiled binary
Question: are the -ca and -ca arguments in the Linux-versions inactive or is the syntax somehow different?
(there is a problem with the alpha-channel in the Wine-Version as well which prevents me from using the wine-LDView as renderer for LDPub, but this is another topic
Im running it under Linux Mint Maya (pretty much a Ubuntu 12.04)
thanks for a reply and best regards, Ingolf
Problems:
