2014-02-22, 9:17
I want to use those helper parts (http://www.holly-wood.it/ldraw/helper-en.html) on MLCad v3.4, but I don't know how to install them because that article was based on o,design MLCad, what can I do?
X = SHOW <LDRAWDIR>Unofficial\Helpers
Max Martin Richter Wrote:The best way is to put them in an addition folder "helpers" in your "unofficial" folder.It is said there ice no Unofficlal folder in LDraw folder..., and even if I copy all filets tomamfolder inside ldraw/parts, no items shown in helperrts tree ..
(<LDRAW Base directory>\Unofficial\Helper).
Then open you MLCad.ini (this is stored in your MLCad folder). Some lines before the very end of this file, you will find a section [SCAN_ORDER]
Just add a line with a new number:
note: X is a placeholder for your number here.Code:X = SHOW <LDRAWDIR>Unofficial\Helpers
Restart MLCad. Maybe you have to set up your parts tree, that it shows the helper. (I'm not sure about this)
Willy Tschager Wrote:Read:It seems look not work...did you try it by yourself?
http://www.holly-wood.it/mlcad/customizing-en.html
Michael Heidemann Wrote:At least here this works.Thanks a lot, I got it.
My Scan Order section looks like:
[SCAN_ORDER]
1 = HIDE <LDRAWDIR>P
2 = HIDE <LDRAWDIR>plasticant\p
3 = SHOW <LDRAWDIR>Parts
4 = SHOW <LDRAWDIR>Unofficial\parts
5 = SHOW <LDRAWDIR>plasticant\parts
Please send yours, so we can see what might get wrong.
