2014-02-03, 15:20
I followed this article to modify PLI control file and specific it in LPub, but it seems doesn't work, how can I use it correctly?
Philippe Hurbain Wrote:Are you sure that you are working with the pli.mpd file located in your LPub\extras folder?Really? I don't know that file has to be put in that folder, I will try it.
Philippe Hurbain Wrote:Are you sure that you are working with the pli.mpd file located in your LPub\extras folder?I am using Mac LPub, there is no extras folder, what can I do?
Philippe Hurbain Wrote:Are you sure that you are working with the pli.mpd file located in your LPub\extras folder?I tried to put pli.mpd file in that folder of my winxp, but no any result what I need, what can I do?
Philippe Hurbain Wrote:I guess you'll have to wait for a Mac user hereI got what I need! my loi.mpd file has mistake and it can be put any folder.
Philippe Hurbain Wrote:All I can say is that it works for me. Did you use a modified version of the pli.mpd provided with LPub, or did you create one from scratch?I copy it from Working with LPub, then I add my own control technic plate parts as below:
0 FILE Technic Plate.ldr
0 Parts List Orientation for Technic Plate with holes
0 Name: Technic Plate.ldr
0 Author: MLCad
0 Unofficial Model
0 ROTATION CENTER 0 0 0 1 "Custom"
0 ROTATION CONFIG 0 0
0 Rotation technic plate 2x4 with holes
1 16 180 0 0 1 0 0 0 0.970296 -0.241922 0 0.241922 0.970296 3709b.dat
0 Rotation technic plate 2x6 with holes
1 16 180 0 0 1 0 0 0 0.970296 -0.241922 0 0.241922 0.970296 32001.dat
0 Rotation technic plate 2x8 with holes
1 16 180 0 0 1 0 0 0 0.970296 -0.241922 0 0.241922 0.970296 3738.dat
0
0 NOFILE
0
Philippe Hurbain Wrote:As you can see, it works (right part was done with your pli.mpd).I got the correct result, thanks again.
One question: did you cleared assembly image cache (in tools menu)? otherwise you keep reusing old orientation again and again...
[attachment=1139]
